Results 1 to 2 of 2
Thread: Reamed Hole ovality
    Jan 2010
    Reamed Hole ovality
    Hi
    If we ream a hole, so in how much ovality is hole manufactured. (The one which is reamed)
    Oct 2005
    the Netherlands
    isn't only a tolerance in size important when reaming.
    a drill will get you a oval hole of over/undersize.
    a ream gets you round but over/undersize.
    and boring gets nice size round holes.
    double check all i might try to make you believe or prepare for the worst.
    Finally CHIPS you can have as much as you can without the doc. complainting about your cholesterol.
  1. Q: Drill diameter for reamed holes.
    By Deviant in forum General Metalwork Discussion
    Last Post: 03-22-2013, 03:59 AM
  2. Replies: 9
    Last Post: 02-11-2008, 11:54 AM
  3. Ovality issues for aluminium parts
    By Viru in forum General Metalwork Discussion
    Last Post: 04-04-2007, 11:40 AM
  4. How best to cut a hole in CNC.
    By cameraman32 in forum Benchtop Machines
    Last Post: 03-23-2007, 01:07 AM
  5. RFQ - Drilled/reamed blocks... 4 quick prototypes..
    By InspirationTool in forum Employment Opportunity
    Last Post: 08-11-2006, 02:01 PM
