Results 1 to 2 of 2
Thread: WSC-6 fanuc 0T-B Drip Feed
    Mar 2010
    canada
    Good Evening.
    Trying to get a WSC-6B lathe made by Murata with Fanuc 0T-B controller to work with Cimco DNC , however cannot get anything out of the serial port.
    The setting that I've followed , are the same that other people implemented on the 0Tb, however without much success. Just to point out that the same machine feeds a 0M on a Kitamura , and can see H13/H11 start and pause characters.
    Io=0, ISO=1, 9600, 7,E,2, when cable is unpluggen and input pressed, the 086 Alarm comes up, which should point that at lest the i/o should work , am I missing or wrong on framing / parity?
    Any ideas suggestions ?
    Thank you all
    Peter
    Feb 2011
    Thailand
    I have a machine CNC Murata WSC-6 Parameter missing data problem and I tried to enter a new Parameter data is not complete, but I want to be the source of Ecืn Parameter to this Or I will discuss the use of CNC machines, please help me with advice and information offline.
    Problem now is to press the start button is double.
    Thank you very much.
    tadaja
    tadaja@gmail.com
  1. Need Help!- Drip feed mode with Fanuc OMA
    By visu in forum Fanuc
    Last Post: 06-26-2012, 08:50 AM
  2. Drip feed for Fanuc 0-MF
    By giorgis in forum Fanuc
    Last Post: 05-08-2009, 11:44 AM
  3. Need Help!- Fanuc 6mb drip feed
    By cowleym in forum General Metal Working Machines
    Last Post: 03-18-2008, 06:25 PM
  4. Drip Feed - DNC - Fanuc 16i
    By gm3211 in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 09-21-2007, 03:43 PM
  5. Drip Feed Fanuc 18i
    By MoldMaker in forum Fadal
    Last Post: 12-26-2006, 11:56 AM
