Results 1 to 5 of 5
Thread: Cutting Speeds for Woodruff Cutters
    Mar 2009
    Does anyone know if there is a chart or formula for calculating the cutting speeds for woodruff cutters?
    Currently I would like to use a 1" dia x 3/16" width of cut in aluminum. But I would like to be able to calculate for all materials and woodruff cutter sizes.
    Thainks in advance for the help.
    Mar 2010
    www.yorklaser.com
    Quote Originally Posted by DonK View Post
    The cutting speed is also related to the thickness of cutting material.
    www.yorklaser.com
    yorklasersmartman@gmail.com
    Nov 2005
    Mark T.
    Variables include material being cut, material of the woodruff cutter and set up specific information. We predominantly uuse HSS woodruff cutters and I then to start off very conservatively. Most have the necked down shank so rigidity is not at a premium. They do make carbide insert woodruff cutters now that can machine much more agressively. In any instance you need to get the recommended SFM and chipload from the manufacturer to use as a starting point.
    Hope this helps
    Mark T.
    Registered BobWarfield's Avatar
    May 2005
    Try this link:
    http://www.niagaracutter.com/techinf...eed/index.html
    They're not going to call out a woodruff specifically, but you can go based on the SFM and number of teeth from their charts.
    Best,
    BW
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
    Mar 2011
    Check any machinist handbook you'll find the charts for woodruff cutters there
  1. Need Help!- feeds and speeds for woodruff cutter
    By tizm in forum General Metal Working Machines
    Last Post: 01-06-2010, 11:41 PM
  2. cutters not lasting when cutting mdf
    By edmond in forum DIY CNC Router Table Machines
    Last Post: 11-03-2009, 12:54 PM
  3. Tapered cutters, speeds and feeds?
    By Haeusser in forum General Metalwork Discussion
    Last Post: 07-23-2008, 08:48 PM
  4. Woodruff Keyseat Cutters?
    By mrcodewiz in forum Dolphin CADCAM
    Last Post: 04-25-2008, 11:15 AM
  5. powermill and slot cutting with woodruff tool
    By krustykrab in forum General CAM Discussion
    Last Post: 02-23-2006, 05:25 AM
