Results 1 to 6 of 6
Thread: Clockwise or Counterclockwise?
    May 2011
    When cutting solid wood,should I have my tool direction clockwise or counterclockwise?
    Jan 2006
    Depends on the tool but most will want to be turned clockwise when viewed from the top. I assume you are using a router or??? I think the router will only go one way?
    Matt
    Dec 2003
    Or do you mean material direction? climb or conventional cut direction?
    Usually climb is preferred in hard wood to avoid shipping as the cutter leaves the material.
    Mar 2003
    Shelby Twp, MI....USA
    Quote Originally Posted by Al_The_Man View Post
    I try to always conventional cut hardwoods. It will usually provide a better cut quality than climb cutting. I only climb cut when it's needed to avoid tearout.
    May 2011
    I am using a CNC Machine and I mean which direction I should have the router head moving when cutting solid wood material,either clockwise or counter clockwise..
    May 2012
    Sweden
    Quote Originally Posted by kitchenplus View Post
    It depends if it is an inside or an outside operation.
    Climb means that the tool has the material to the right, seen from above,
    and vice versa with conventional.
    Climb is most commond in steel, but i think that conventional is better in wood.
    1. Counter-Clockwise Lead-in
      By daedalus0x1a4 in forum Mastercam
      Last Post: 10-13-2011, 02:33 PM
    2. could a 3 phase servo run clockwise only???
      By patriciooholegu in forum Servo Motors and Drives
      Last Post: 10-27-2010, 05:03 PM
    3. Need Help!- counter-clockwise vs clockwise arc problem
      By loedward22 in forum General Metal Working Machines
      Last Post: 10-08-2009, 12:56 PM
    4. Clockwise only, XYZ- and +?
      By lbrc in forum Mach Software (ArtSoft software)
      Last Post: 06-20-2007, 11:25 PM
