Sounds like an open node chain (object is not closed. To close the object from two node chains first select both and do a COMBINE. Then using the node editing tool drag the end nodes of one over the top of the other and they will form a continious chain. bring the end node of the new longer chain back over the beginning node to CLOSE the chain and make a closed object.
TOMcaudle
www.candcnc.com
PS post over in the CNC plasma section for better help
LinkBack URL
About LinkBacks
