Why don't you unhang the ladder? If you have not changed (or lost) the parameters I'm not sure how you think changing them will help???
I have a cnc lathe make AKEBONO fitted with Fanuc 11T controller.
Model- super4 AC-35
year of manufacture-1986
Machine is fitted with twin turrets.When it is switched on , the ladder is shown in hanged position. No command is executed properly. Does anybody have the same make and model machine so that I can get the PLC parameters to override mine.
Plz reply at the earliest........
hey keebler, thanks for the reply....
can u suggest some way of getting out of this problem.....as in some method u know to unhang the ladder.....and i dnt wnt to change the parameters...its dat if somebody has the same make and model of the machine ...i cn get the parametrs from him.....
