Results 1 to 6 of 6
Thread: Please help with Daewoo DMV 3016 Alarm
    May 2011
    Exclamation Please help with Daewoo DMV 3016 Alarm
    My Mill errored out while running a flat piece of material. The alarm came up on the screen as (Spindle Tool Clamp/Unclamp Alarm) The Alarm Number is (AVE0166) Any help getting back up and running would be extremely appreciated.
    Thanks Alot.
    May 2011
    Sorry I didnt specify. I just need to know how to reset the alarm. I have shut the machine down and started it back up. It still wont reset.
    Thank you.
    Aug 2010
    sounds like a prox switch above the spindle that confirms tool clamp.
    May 2011
    Ok thanks Im going to climb up there and check it. I will let you know if it worked
    May 2011
    I should also mention that the machine error was caused by stalling out in a run.
    May 2011
    Well the proxy switch option didnt do it. Any other options besides calling a tech? Thanks again.
    1. Daewoo DMV 3016 - need help with physical repair
      By daewooDmv3016 in forum Daewoo/Doosan
      Last Post: 10-31-2010, 01:17 PM
    2. Disabling door interlock on Daewoo 3016?!?
      By SeanC in forum Daewoo/Doosan
      Last Post: 12-05-2009, 03:39 PM
    3. Need Help!- DAEWOO 8 Steady rest pressure alarm, External feed hold alarm
      By doubleeagle in forum Daewoo/Doosan
      Last Post: 06-12-2009, 04:15 PM
    4. Newbie- Daewoo DMV 3016 error No. 2079
      Last Post: 04-29-2008, 08:35 AM
    5. Daewoo 240 alarm
      By BruceinOZ in forum Daewoo/Doosan
      Last Post: 04-30-2007, 05:35 PM
