Results 1 to 2 of 2
Thread: Thermo-forming of 3D Laminate
    Apr 2011
    I am getting a web on the outside corner of a part. How do I set blocking to eliminate the web? I have attached a picture to clarify what I mean...notice the crease (webbing). I have also included pictures of the problem area. Let me know what you think. Thanks!
    Attached Thumbnails Attached Thumbnails Thermo-forming of 3D Laminate-partcrease1.jpg   Thermo-forming of 3D Laminate-backcrease.jpg   Thermo-forming of 3D Laminate-frontcrease.jpg
    Feb 2010
    You need to positin you blocking to stretch the material and have it pull back in. I would put web chasers aka blocking on the left and right of the corner. Start high and then whittle it down. Just be mindfull of to high will thin the corner significantly. How much flange and bleed for trimming is on the mold. Thin tall web chaser may be better than blocks and you could only need one on one side.
  1. Need A Quote- 2D Carbon Laminate
    By AuroraDrvr in forum Employment Opportunity
    Last Post: 11-17-2009, 11:55 PM
  2. Laminate then cut or cut then laminate?
    By marksolberg in forum Commercial CNC Wood Routers
    Last Post: 01-24-2009, 07:04 PM
  3. Thermo Dynamics/High Frequency/THC
    By Firebass in forum General Waterjet
    Last Post: 08-18-2008, 10:40 PM
  4. Problem- thermo part sticking to artwork?
    By spock in forum Vacuum forming, Thermoforming Etc
    Last Post: 05-05-2008, 10:24 PM
  5. solid Laminate
    By jaywhy71 in forum WoodWorking
    Last Post: 10-10-2007, 07:24 PM
