New Machine Build DIY- CNC Embroidery Machine - Page 75
Page 75 of 75 FirstFirst ... 25 6572737475
Results 889 to 894 of 894
Thread: DIY- CNC Embroidery Machine
  1. #889
    Sep 2016
    Morocco
    Default Re: DIY- CNC Embroidery Machine
    DIY- CNC Embroidery Machine-20150828_192031-jpgMy dear khalid
    I am very impressed with the work you do, so I want you to help complete the project
    My problem, I transform the Coordinated to the pwm
    DIY- CNC Embroidery Machine-1-jpg
    DIY- CNC Embroidery Machine-2-jpg
    These images, I use vb.net
    Attached Thumbnails Attached Thumbnails DIY- CNC Embroidery Machine-1-jpg   DIY- CNC Embroidery Machine-2-jpg   DIY- CNC Embroidery Machine-20150828_192031-jpg
  2. #890
    Gold Member Khalid's Avatar
    Apr 2006
    Pakistan
    You already doing good.. Your project is very seperate from my work.. i dont have experience in VB.net...
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
  3. #891
    Sep 2016
    Morocco
    Quote Originally Posted by Khalid View Post
    Thank you, my brother has Rotk working with VB6 My question is not how to transform Coordinates into action ?
  4. #892
    Aug 2016
    Default Re: Contribution
    por favor ivan pasame la informacion de esta maquina peruana de costura.
    please send me the information of this machine.
    I want to build one.
    muchas gracias.... es que el enlace esta roto
    muchas muchas gracias
  5. #893
    Gold Member
    May 2006
    Hi Khalid, I am seriously thinking of adding an embroidery machine to my project list, but first a couple of quick questions...
    Has anybody got a machine up and running yet ? I am very lazy and if there is a working design I can copy all the better, haha.
    Am I correct in thinking that your software creates the G code only, to run on Mach or Linuxcnc or whatever ?
    I would assume the XY frame holding the material needs to stop for the time the needle is through the fabric, what addresses this in g-code? I am thinking an encoder on the hand wheel thingy on the end of the machine, so the XY moves to position, wheel turns through the "needle in the fabric zone" then once the needle is clear the XY moves to the next position before the needle is starting to go through the fabric again...then keep this process going.
    I have some unused servos, drives and assorted bits and pieces, might be worth having a go at it.
    I guess these questions have already been mentioned in this thread somewhere but I did mention I am lazy !! I will start reading through from the start in any case, I am sure it will help me to get a grasp of what is going on.
    Cheers.
    Russell.
  6. #894
    Dec 2015
    An India-based alloy steel flanges exporters & manufacturers, Saini Flange Pvt Ltd is a leading supplier of steel flanges, pipe fittings, auto parts, valves, Traub components manufacturer & high precision CNC machined components. Our company has been delivering a wide range of flanges around the world (Europe, North America, etc.) since 1995. Here are the products that we deliver:
    Ring Flange
    Blind Flange
    ANNULUS RING
    Vacuum Flanges
    Exhaust Flanges
    Fitting Flange
