Kiefer, thank you for your help...
I also have a 6 color Brother PR620 Embroidery machine that I currently use as a hobby for embroidery with Wilcom Software to digitize. So I will be able to compare any samples with both machines and software.
I don't have much experinece with CNC other than this embroidery machine I have had for the last few months.
I don't have MACH3 software (how can i get it?)...But I do have Windows7 computer. I have built several computers over the years and have built a couple of drones so I have no problem to wiring and connecting motors and components with instructions.
Hardware- It looks like all the XY motors have encoders...does this make them servo motors? The brushless main drive motor has a speed controller and the motor has a little board ( maybe encoder) attached to the end shaft with a ribbon cable (10 pin maybe?) going straight to the mother board. There is just a motherboard and no BOB I believe! There is also a little board near the color changer that Im not sure what componets they all consist of to change the needle color position...
Please let me know which parts I will need to order so I can get them ASAP? Will I be able to use all the original XYZ motors on the machine?
Hope I have given you enough info...Thanks again for your help...really looking forward to this project.
PS: I also have another Melco single color machine with all the same XYZ motors and board... without the color change.
