My New 24x24 V-Groove Router Design Log - Page 51
Page 51 of 57 FirstFirst ... 4148495051525354 ... LastLast
Results 601 to 612 of 675
Thread: My New 24x24 V-Groove Router Design Log
  1. #601
    Gold Member jalessi's Avatar
    Feb 2007
    Items for Sale
    Post
    Eric,
    you need a Moschip 9800 series chipset.
    The 9700 series is old stock that does not support XP.
    If you look on the Moschip IC you will see what I am talking about.
    See the attached links.
    SYBA SD-LP-MCS2P
    http://www.syba.com/index.php?contro...on=Info&Id=563
    http://tinyurl.com/qocamv
    http://www.adeltek.com/Product%20Dri...d-lp-mcs2p.zip
    Jeff...
    Attached Thumbnails Attached Thumbnails My New 24x24 V-Groove Router Design Log-pp-pdf
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  2. #602
    Gold Member widgitmaster's Avatar
    Jun 2005
    I think I found a reliable source for quality Dual LPT boards!
    I remembered "Black Box" sells all kinds of IO boards!
    This is too frustrating for me, I'd rather be cutting metals & plastics!
    Widgit
    www.widgitmaster.com
    It's not what you take away, it's what you are left with that counts!
  3. #603
    Jun 2005
    Oh Well!
    After calling Black Box, their tech support told me that board does NOT have Windows-XP drivers either!
    ARGGGGGGGGG.................
  4. #604
    Jun 2005
    After calling five major suppliers, such as Black Box, Mouser, Texas Instruments, they all had the same story! The LPT interface is soon to be obsolete, and they have discontinued all of their Parallel Port add-on card products!
    So my question is this:
    Can I use an Digital-IO card to preform the same tasks in Windows XP using Mach3?
    Eric
  5. #605
    Gold Member acondit's Avatar
    Apr 2005
    Quote Originally Posted by widgitmaster View Post
    Oh Well!
    Eric,
    Try this site http://www.newegg.com/Product/Produc...82E16815166006 or http://www.newegg.com/Product/Produc...82E16815166005. The second link is a single parallel port. Their specifications says that it supports XP and vista.
    Alan
  6. #606
    Jun 2005
    Thanks Guys,
    I have ordered one of their LPT cards, I hope it works with XP!
    It does have a 9800 series Moschip chip set as suggested by Jeff!
    Eric
  7. #607
    Gold Member BobWarfield's Avatar
    May 2005
    Eric, I love the vacuum manifold. Perfect for the little tiny chips that high speed spindle will throw off.
    Sorry I didn't get to this thread sooner to comment on the computer stuff. The parallel boards you ordered will hopefully do the trick. If not, I have a couple suggestions. First, call the peeps that sold you a breakout board (I forgot which you got, CNC4PC?) and ask them to recommend a parallel card.
    Second, you can avoid the cards altogether with a Smoothstepper. It gives you 2 parallel ports with a USB cable. That's what I'm using and it has worked pretty well. Not cheap, though.
    Cheers,
    BW
  8. #608
    Jan 2008
    canada
    Eric:
    have a look at these. It works on my XP system.
    http://www.lavalink.com/index.php?id=254
  9. #609
    Jun 2005
    Good news!
    Last night I received the ribbon cable and IDC plugs which were ordered from Mouser.com, I made a new 36" long 25-pin ribbon cable to connect the breakout board to the motherboard's LPT port.
    This is the first time I have had the ports connected with the newly installed OS, and I have to say the motors are responding smoothly without glitches, or noises! The computer's red IO light did not blink for over an hour
    So I re-tuned my motors, and now have them moving at 325 IPM!
    I stayed up till 2:30 AM just watching it run, with a BIG smile on my face!!
    Now all I need is another port to get the MPG installed and working!
    Widgit
  10. #610
    Jun 2005
    LPT1 Pins:
    1 Output#1 (Spindle on/off)
    2 X-Step
    3 Y-Step
    4 Z-Step
    5 A-Step
    6 X-Dir
    7 Y-Dir
    8 Z-Dir
    9 A-Dir
    10 E-Stop
    11 X-Home
    12 Y-Home
    13 Z-Home
    14 Output#2 (Vacuum on/off)
    15 A-Home
    16 Output#3 (Aux AC outlet on/off, vacuum pump)
    17 Charge Pump
    CPU =1.8GHz
    RAM = 2 GB
    Kernel Speed = 75000hz
    Steps Per = 10160 (5.0 mm pitch)
    Velocity = 441
    Acceleration = 65
    G's = .24608
    Step Pulse = 3
    Dir Pulse = 3
    Feed rate while running at MAX = 628.81 IPM
  11. #611
    Jul 2007
    Sweden
    Eric,
    Not that it matters much but I still don't understand....
    You had it all up and running - on XP - but the RAID system or something messed up the timing so you re-installed the operating system. But now you need to get new LPT-cards and longer cables because the ones you've got doesn't support XP....
    How come it worked on XP before you reinstalled XP?
    Anyway, I'm glag you got it going!
    /Henrik.
  12. #612
    Jun 2005
    The last time I installed everything, I battled with the drivers until windows finally accepted them! The only driver that it would accept was for Win2000.
    So by eliminating the problem LPT card, I was forced to use the LPT port on the motherboard. That required a longer cable, as the port was outside the big steel drawer. The reason for using add-on LPT cards, is they have a set of pins on them for the 2nd port. It's really east to make a cable to connect the pins to the breakout board. Also, if something were to damage the LPT card, its easier to replace the card than the entire motherboard!
    As for the problems with XP, there was too much stuff installed, like anti-virus, network, raid, sound. So by eliminating them all, the number of tasks has been reduced to next to zero! This allows the OS to run MACH3 without interruption!
    Eric
