New Machine Build Profile 8 Alu CNC Advice
Results 1 to 8 of 8
Thread: Profile 8 Alu CNC Advice
    Dec 2016
    Switzerland
    Default Profile 8 Alu CNC Advice
    I'm working on a new CNC since a few months. Is it possible to take a look at my new design? All suggestions are welcome
    It should have a final size of 1600x1100. I use profile 8, Hiwin hgr20, 800w water cooled spindle, 4X nema 23 KL23H2100-35-4B with a Gecko G540, 48v PSU, LinuxCNC.
    The machine should be able to cut wood and alu. The machine have to be strong and reliable.
    • Is there an specific place where the spindle is mounted in order to optimise the distribution of forces. Should the spindle be in the middle of the Y rail?
    • Is 12mm thick aluminum 6061 enough for the plates?
    Thanks for your help
    Attached Thumbnails Attached Thumbnails Profile 8 Alu CNC Advice-cnc-v21-recovered-jpg
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Profile 8 Alu CNC Advice
    With the Hiwin's, it doesn't really matter that much.
    You might want to make the side plates a little wider, to increase the bearing spacing a bit more.
    The thicker the plates, the better. Maybe 15-20mm?
    And I'd get a 2.2Kw-3Kw spindle. The 800w is too small imo.
    UCCNC 2017 Screenset
    Dec 2016
    Switzerland
    Thanks for your answer.
    I will make the changes.
    I was looking for someone that can waterjet cut 20mm aluminium plates, but it's pretty rare (and not cheap!)
    Do you have maybe any recommendation ? Or maybe is it better to use another method?
    Thanks.
    May 2011
    Quote Originally Posted by BriceO View Post
    Thanks.
    I had some 1 inch aluminum plates waterjet cut for my first build. It was expensive, and the quality was absolute garbage. The cuts were not square. I had to rework them on my mini mill to make them square and proper.
    Find someone with a machine in your area who does this as a hobby and can help you. Perhaps someone with a smaller machine can make the plates and in return you can make a larger wood carving for him.
    Do you have access to a mill?
    There's always the angle grinder and drill press method.
    Apr 2009
    A consideration for where the spindle is in relation to the bearing blocks would be work envelope. If the spindle center is past the constraints of the bearing blocks, you'll lose work travel over the table, though it could allow machining past the table. The ideal location of the spindle has more to do with having the CG of the entire gantry assembly fall between the two bearing blocks, as to evenly "load" them.
    Waterjet cutting is not cheap. It may be more economical to have them machined, as well as more accurate.
    Quote Originally Posted by NIC 77
    Some alloys will waterjet better than others. The nature of the process causes the kerf to have a draft, as the abrasive media is "blasted back" by the material itself before cutting through. Higher end waterjets have a 2-axis head, which allows for compensation, producing a square cut.
    Mar 2014
    Thanks.
    Aluminum can be cut with a plasma cutter. A machine shop or welding fabricator may have a plasma cutter where a waterjet would be uncommon. If they are uncomfortable cutting aluminum on a CNC plasma cutter, maybe you could change your design and make the plates out of steel?? Your part would be stronger than aluminum and may cost less when the cost of waterjetting an aluminum part is factored in.
  7. #7
    Apr 2009
    Quote Originally Posted by 1Jumper10 View Post
    Plasma presents similar problems to waterjet as far as the slight draft or angle at the cut edge. Though, with steel, the part could be made a little thinner.
  8. #8
    Dec 2016
    Switzerland
    I have received an estimation today for Aluminium 6082 T6 : 200Frs(184 Euro) / plate.
    is it a good price? It seems too expensive.
