https://tinyurl.com/hp8o2u5 Cost about 200 usd Similar Threads:Just In Samples made by Roctech 4 axis CNC machineNeed Help!- Postprocessor for self-made 3 axis cnc milling machine BOATS MADE BY ROCTECH 4 AXIS ATC MACHINE MFG CNC Machine Z-Axis Zero Tool Setter Pro -MADE IN THE USA- MFG CNC Machine Z-Axis Zero Tool Setter Pro -MADE IN THE USA-
Very interesting! You said the machine was based on a Gatton plan. Did he do a fixed gantry machine?? Is that a C shaped pieced of steel and how did you do the linear bearings within it? Tnx,
thank you
View Tag Cloud
Forum Rules
