Build Thread Last One - 4'x6' Steel, Epoxy and ClearPath servo's - Page 36
Page 36 of 36 FirstFirst ... 2633343536
Results 421 to 423 of 423
Thread: Last One - 4'x6' Steel, Epoxy and ClearPath servo's
  1. #421
    Registered assadi's Avatar
    Feb 2015
    Default Re: Last One - 4'x6' Steel, Epoxy and ClearPath servo's
    great information and ideas I found here.
    For plasma CNC ( stepper motor 1.8° with planetary gearbox 3:1 + micro stepping probably 10x) what you recommend me to use, rack and pinion module 1 or 1.5 ?! And what is the best (ideal) pinion diameter (number of teeth for the pinion ) ?!
    What is the advantage of helical rack ?!
    Appreciate your help!
    Sent from my A0001 using Tapatalk
  2. #422
    Mar 2014
    Assadi - Plasma is a different machine with different requirements. Anything I could tell you would be just a guess on my part. With that said if I were building one I would use regular straight rack and not helical, or even a good belt drive system. You want speed more than rigidity (to a point). And use good shielded cable on all your wires. There's lots of electrical noise on a plasma machine.
  3. #423
    Mar 2003
    Helical is quieter, and can carry higher loads.
    Number of teeth depends on the motor and drive, gear reduction, and how fast you want to go.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
