Build Thread Last One - 4'x6' Steel, Epoxy and ClearPath servo's - Page 30
Page 30 of 31 FirstFirst ... 202728293031 LastLast
Results 349 to 360 of 369
Thread: Last One - 4'x6' Steel, Epoxy and ClearPath servo's
  1. #349
    May 2011
    Default Re: Last One - 4'x6' Steel, Epoxy and ClearPath servo's
    Quote Originally Posted by 1Jumper10 View Post
    Anyone want to buy some almost brand new Pepperrel and Fuchs proximity switches ??
    Woah, those aren't cheap. $30 each + shipping and tax. You've got me thinking about prox switches now. How are they wired? They need to be powered with 10 to 30 volts? So what is that, 4 wires to each, or ??? Power and ground, then two for the circuit for the switch, no, it must be another way?
    I have only used the mechanical switches, also from CNCRP, where it actually closes a switch, allowing current to flow through the two wires.
    So these prox switches are 3 wire?
    You should probably hold onto them until you've got everything working how you want it. Too expensive for me, I am poor.
    I did just now do a search on EBay, I wonder what the quality is like between these switches and ones I can get on EBay 10 for $25 USD?
  2. #350
    Mar 2014
    These are it here: Pepperl + Fuchs Proximity Sensor Kit | CNCRouterParts
    I'm going to keep them for now in case I cant get the Hard-stop homing feature to work. They are wired through the cable chains but I'm not going to terminate them on the MB2 unless I end up using them.
    They are 3 wire, 12 -24vdc, inductive (?) proximity sensors. You can probably find similar sensors on E-bay but these are really high quality units. I was impressed with the sensors, cables and the connectors. Very well made. In this case, I did get what I paid for. I'd sell them for $100 shipped in case you were interested and I ended up not using them.
  3. #351
    May 2011
    For the last few minutes I've been doing some research on this, I haven't gotten into it before.
    So it was a few years ago that I made my control box, I can't remember all I did on it now. I'm pretty sure I'm using Normally Open (NO) limit switches, because if I hit a limit inadvertently, I would unplug the wire from the back of the control box I made to be able to jog it away from the switch. Looking on EBay, there are 2 wire Normally Open Prox switches for sale, 6 to 36 VDC, I'm guessing those could be plug in replacements as far as my control box is concerned, no messing around with a third wire?
    Do you remember those little square mechanical switches that CNCRP used to sell? That's what I have. I think I will leave them attached to my first build, and get some 2 wire NO prox switches for this one.
  4. #352
    Mar 2014
    If the switch requires power to operate then its almost certainly 3-wire and I think its more correctly referred to as a sensor; normally Hall effect (senses the presence of a magnet) or proximity (either inductive or capacitive). 2 wire switches are normally mechanical, or reed switches that sense the proximity of a magnet. I've used all types and the hall effect sensors I felt were best suited for use on a DIY router. Current type hall effect sensors are only 2 wire and require a magnet as a target. They're pretty easy to implement but they've become harder to find lately. Standard hall effect sensors require power to operate but they are dirt cheap and are usually very accurate. You'll probably have to make your own housing for them. I think, haven't tested, that mechanical switches are the least accurate type of switch/sensor.
  5. #353
    May 2011
    I found some two wire proximity sensors on EBay. Not sure what the difference is? I realized I've started to derail your thread going off on a tangent about my own needs, so I made a post here:
    Please School Me On Proximity Switches
    Hoping to find a two wire solution, or I will probably just use the mechanical limit switches.
  6. #354
    Mar 2014
    Pretty frustrating past couple of days. I installed and auto tuned the servo on the Z axis and that went well and is working good. I can jog or send it to positions with the MDI. Same with the X axis. The dual motor Y axis will have to wait awhile yet. This confirms to me that I've connected the step and direction inputs at the board and on the servo correctly. But I've got a problem with the outputs on the MB2. Not sure how but the outputs Y301 - Y304 failed first, followed by the second group Y305 -Y316. They fail to an on state. I could not figure out why my spindle run command was active on the VFD but not in software or the MB2. Started checking outputs with my multimeter and all outputs had -24vdc no matter if the LED on the board was lit or not. I began to realize that I had burned up 4 outputs somehow and shifted my enable circuits and relay output down to Y305 - Y316. Now, they are fried to. I don't think I hooked up anything incorrectly. If my servos weren't working as expected I would suspect I did. Not sure about the path forward from here. If anyone has suggestions I'm all ears.
    Sent from my Pixel XL using Tapatalk
  7. #355
    May 2011
    As you know from my other posts, I am no expert on BOB wiring.
    What was connected to those ouputs? Was this because of the VFD connection to the board?
    So this is a MachBob2 board?
    Is one of these user manuals correct?
    Rev 4
    http://www.cncroom.com/downloads/MB2...al%20E16R4.pdf
    Rev5
    http://www.cncroom.com/downloads/MB2...al%20E16R5.pdf
    It could be that your VFD has an issue that was the cause of this? Either a fault in the VFD causing too much current to flow, or a miss matched spec, or incorrect wiring? Could be your VFD is missing a resistor?
    "Figure 12 shows 14 output terminals, each output can sink current up to a maximum of 100mA with a total maximum of 500 mA per group of 7 outputs, as shown in Figure 1 on page 4"
    Do you think it got too much current?
    Is there a way to test the current flow these outputs saw using a battery and multimeter connected to the VFD or whatever was attached?
  8. #356
    Mar 2014
    It is the MachBob2. I suspected the VFD at first. Not because it is defective somehow but maybe I had hooked it up backwards. The MB2 uses "sinking " transistor outputs (as near as I can tell but spelled out in the MB2 manual) The VFD has a jumper that you set to accommodate your inputs which would be "sinking". Set it, tried it, but they were probably already toast by then and I never did get it to work correctly. Eventually I gave up and shifted it down to the "CM" and "NO" of the onboard relay and then it was fine. Anyway, the current requirements of the enable circuits and the VFD and a couple external relays in total were far below what the MB2 is rated for : 24 miliamps for the 2 enable circuits, about 6 miliamps for the relays. MB2 is rated at 100 miliamps per output, 500 miliamps total. Both times it happened were right after turning on the power and I think that is what fried them.
    I reached out to CNCroom to see if they could provide some insight.
  9. #357
    May 2011
    How goes the battle? Were you able to get it working with your board through other inputs or are you now looking at needing a new board?
  10. #358
    Mar 2014
    Cncroom has been very helpful. Said the board could be repaired and they offered to send me the components to do it. I thanked them but declined. I asked if they could look over my wiring diagram to make sure I was doing it correctly. Weerasak had me send him the manual for the servos and the VFD and tell me how it should be connected to a UB1 board. It was going to take him a couple days to get back with me and in the meantime I got a new UB1 board ordered and on the way.
    I am convinced there were only 2 things that could have fried the MB2 outputs: a sinking-sourcing conflict with the VFD, or a power surge from everything powering up when the contactor was closed. So, new plan is to separate the servo power supply and VFD from the UB1 with a 2 pole contactor controlled by the charge pump output. The UB1 will power up, followed by the software then the servo power and VFD.
    It's a helluva way to upgrade my control board to a UB1. Can't say I recommend it.
  11. #359
    Mar 2003
    So, you were using an output to the VFD fwd input? I only used the MB2 relay for that.
    I'm actually using an 8 channel 24v relay board for my contractors coils, so I don't accidentally blow up my board. Since I don't know what I'm doing. 😃
    I managed to blow a DYN4 drive the other day, but it didn't damage the UB1. Now I have to send it to Canada for repair.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  12. #360
    Mar 2014
    Yes. Yes I was
    It seemed so reliably simple and it will work that way but it is complicated. I switched it over to using the relay after it was too late for the MB2 outputs and that worked just fine too. I might leave it that way but Weerasak sent me a diagram of how to do it. He also pointed out that the Hitachi could use Y301 for the pulse stream instead of one of the axis outputs. Just assign it as the output for the Step/direction Spindle set up in UCCNC as the motor spindle step signal. Anyway, he's been very helpful and here's the diagram he sent me.
    Attached Thumbnails Attached Thumbnails Last One - 4'x6' Steel, Epoxy and ClearPath servo's-nmiemeonlmnnlnnk-png
