Hi everyone!
I am new here. [COLOR=#000000][FONT=arial]
Here is my current plan of action:
#1 The base of CNC will be made from rectangular steel tubes(Recently, I applied to welding courses, to finally learn welding)
Why steel, not aluminum extrusions? Because here, where I live, aluminum extrusions are hard to get and relay expensive(Cheapest 4080 extrusions and assembly hardware for this project would cost me like 400€), but steel would cost me less 75€.
#1.1 I will start by making Y gantry from 100X150X4mm square tubing, in which I will cut necessary holes.
After making those holes - I will send it out to local metal shop, to machine it flat, because I am sure, that the tube will warp quite a bit, after cutting holes in it. After that - I will weld the legs of gantry to it.
[The tube shouldn't warp too much if you drill the holes. If you cut them with a torch, it will warp a lot. Machining won't help, because the tubes are too thin; if you machine off too much of them, they will lose their strength. Try clamping things down to your granite while you're welding them flat, and skip around, avoiding getting too much heat in any one place at a time.]
#1.2 The base of the machine I will veld from 50X50X4mm and 100X50X4mm steel tubing.
To make X axis as flat as possible(in my powers) - I plan to use granite counter-top as a guide(granite surface plate is not an option in my country, with my budget).
#1.3 The gantry won't be welded to base, but attached with 4 bolts, so it is possible to square and tram the Y axis in future.
[If you can't make things perfectly flat, make them adjustable, so you can use shims to achieve square and tram.]
#2 Aluminum hardware.
For most of structural parts I plan to use 10mm thick aluminum. Because I don't have necessary tools to precisely make most of these parts - I plan to order 2D CNC cutting of these parts. I think I will be able to fit everything on 550X750mm sheet.
#2.1 To assemble everything - I will need to drill and tap a few holes in sides of previously mentioned 2D machined parts and that I will be able to do by myself on a drill-press.
[It's not clear which parts you're talking about here, but you only need to use aluminum for moving parts where weight is an issue. Otherwise steel will be stronger and cheaper. The only parts on the design pictured above that move are the table and the piece that holds the Z axis. If you've got a machine shop to work with, use them to put T-slots in the table base that fit whatever inexpensive clamping kits are available in your country. You can also use the aluminum to make mounting plates for your motors.]
#3 Rails.
For guide rails - I will risk getting cheapo AliExpress HGR15 linear rails. 600mm X-axis, 600mm Y-axis and 300mm Z-axis. This would make my CNC's working are approximately 400X470X170mm. Although, this is not cut in stone, because my plans may change, if I get a good deal on other lengths. Actually, I am considering using SBR16 rails for X-axis, because X-axis should have the least amount of load and for the price of 600mm HGR rails I could get 1000mm SBR rails.
[The HGR rails will work a lot better. If you want to cut aluminum reliably, use them throughout, not the round rails.]
#4 Linear motion hardware. For moving X and Y axis I plan to use 1204 ball-screws. For Z-axis I haven't decided between ball-screw and lead screw. I think lead screw is better choice for Z-axis, because it is possible to get them with smaller pitch(like 1mm), making it less likely for Z-axis creep under the weight of spindle.
[Get the C7 grade ball screws, which are more accurate than the lower grades of rolled ball screws. The Z axis has the most weight to lift, so the use of a finer-pitched screw will give you better mechanical advantage as well as back-driving less.]
#4.1 As for ball-screw bearings - I still haven't decided between ready made ball-screw support blocks and custom made ones, that I could machine with previously mentioned(#2) CNC machining operation. In the end - it all will come down to price and convenience.
[Most people advise getting dual angular-contact bearings to fix one end of the screw firmly in place, but letting the other end be lightly constrained, so it can expand and contract without warping.]
#4.2 Another field about what I am not totally sure is connection between ball-screws and steppers.
#4.2.1 I would like to attach X-axis ball-screw straight to stepper(with flexible coupling, of course).
[That should work okay; I'd say use an oldham-style coupler with a zero-backlash spider. The inexpensive aluminum helical couplers fail quickly in CNC applications.]
#4.2.2 For Y-axis I haven't decided between attaching ball-screw straight to stepper and using timing belt, because I am not sure yet, what could be most convenient way to mount motor to the gantry.
#4.2.3 Z-axis I will most definitely mount with timing belt. The reason why is, because I think that mounting motor straight on top of ball screw would place the motor very high, that would make it top heavy, therefore making it prone to unwanted vibrations. So, by mounting stepper using timing belt - it would somewhat equally balance weight between spindle and stepper motor.
[I'm not sure that's such a big issue; the added weight of the pulleys and the mechanism that holds them would tend to cancel out whatever benefit lowering the motor would confer.]
#5 For motors I plan to buy one of 'those' cheapo 3 axis Nema23(57BYGH115-003B) kits. Although, as I understand, controller boards of these things aren't the most reliable things, so I will need to upgrade it as soon as I can.
[Avoid buying the drivers and motors until you've built the rest of this thing. Those cheapo kits usually feature underpowered drives and motors with a lot of inductance that require a lot more power than the drives can handle. People who buy them often end up buying something else when their machines don't work right. In the meantime, you can read about motors and drives to make a more informed decision.]
#6 For spindle I will probably go with 2.2kw water cooled one, if it will fit within my budget. If not - 800w air cooled one will do(for some time).
[More power is better. Air-cooled spindles are generally preferred. Watch out for improper grounding on those Chinese spindles, though.]
#7 After assembling everything - I will square and tram everything by moving and shimming the gantry(that is mounted to the base with 4 bolts). For attitudinal corrections - I think I will be able to shim spindle mount to z-axis.
Soooo... - his is my plan, so far. I would like to hear criticism/suggestions/corrections about this plan. Is there anything I am missing?
Like I mentioned multiple times before *rolls eyes* - I am rather inexperienced in machining and similar stuff, so some additional educational resources won't come to the detriment.
