Momus Inspired Build Log
Results 1 to 10 of 10
Thread: Momus Inspired Build Log
    Jan 2016
    Default Momus Inspired Build Log
    I'm currently in the design phase of my CNC and its loosely based on the Momus design as I really like the sunken bed. I'll be drafting the design using AutoCad and the slowly purchase/build it over the course of a year or so.
    I hope to have a cutting area around 4' x 4' X/Y and a 1' Z using Linear Rails/Ball screws.
    Attached is the first draft of the frame which is made from various grades of T Slot (90mm x 90mm, 90mm x 45mm and 45mm x 45mm) and the frame size is 7' x 7' x 2' (with a 1' sunken bed). Keep in mind this is a first draft and will more than likely change.
    Attached Thumbnails Attached Thumbnails Momus Inspired Build Log-base-design-jpg
    Jun 2012
    Default Re: Momus Inspired Build Log
    First look, the top long corner, 2 on each side, the break in the mid looks funny to me. maybe one on each side should be 1 piece. not sure it make any different, look strong.
    I like the sunken bed also.
    Jan 2016
    Quote Originally Posted by SteveWill View Post
    I'd had done that so I could have another 3"x3" support in the center for the gantry load. I thought about just framing in 1.5"x3" but was unsure if it would be ridgid enough considering the 7' span. The whole base will also be covered with ply/mdf so that will add some support as well. So you maybe right to remove the 3x3 and replace with a 1.5x3. Anyone else got any input?
    Jan 2016
    I have revisited my design and realized that It was extremely to big (wanted 4x4 cut area and it was more like 4'x6') and down sized it so I'll have a 3'x3' cut area (probably a little more) with total base mesuring 5.5' x 4.5'. I also took the advice and removed the center post. Any thoughts on the new design?
    --James
    Attached Thumbnails Attached Thumbnails Momus Inspired Build Log-base-small-jpg
    Jan 2016
    Well after pricing this new base out I think I'm going to re-think this. The base alone (without the gantry) is about $1600CAD + shipping which is a little nuts IMO. I'm thinking about drafting a similar base in steel tubes as its about 1/4 of the price. Anyone done a steel base in place of aluminum?
    --James
    Jan 2008
    Go with big steel tubes. You don't need to fabricate a complex structure like that. Big steel tubes!
  7. #7
    Jan 2016
    I'll draft one up in the next few days with steel, probably use 1"x3" rectangle steel tubes for the frame and 1"x1" for the bed. I'll post when completed
  8. #8
    Jan 2008
    1 inch tubes are too small. Steel is cheap. Go for 4x4" tubes or bigger.
    My build: http://www.cnczone.com/forums/diy-cn...ded-steel.html
  9. #9
    Jan 2016
    Really no need to go that big for a frame. I'll probably use 3"x3" for the posted and something similar for the gantry but framing all in 4"x4" would just ad unneeded weight IMO.
  10. #10
    Jan 2016
    Sry for the delayed update but I have been pretty busy. I actually stop designing this as I came across a used Ooznest OX CNC kit and have been working on getting it setup over the past few months (ordering supplies and such). I'm pretty close to finishing up the controller box using an old Mac pro case and will be working on the actual OX assembly soon. The size of the OX is 1000mm x 1000mm so I had to build a custom table that is 5'3" x 4'3" which has been awesome to build the controller on (will miss the area once the OX is sitting on it). Hope you enjoy the photos and if you have any questions just let me know.
    Attached Thumbnails Attached Thumbnails Momus Inspired Build Log-0-jpg   Momus Inspired Build Log-2-jpg   Momus Inspired Build Log-3-jpg   Momus Inspired Build Log-5-jpg
    Momus Inspired Build Log-6-jpg   Momus Inspired Build Log-8-jpg   Momus Inspired Build Log-9-jpg   Momus Inspired Build Log-10-jpg
