# Teknic.com
(4) $1676 - ClearPath® - Integrated Servo System (CPM-SDSK-3421S-ELN)
(1) $248 - Clearpath The Amazon™ Intelligent Power Center (“IPC-5”)
(1) $49 - ClearPath Power Distribution Hub
(1) $12 - 24 Volt Power, 2-Pin Molex Cable (CPM-CABLE-M2P2P-120)
# cncdrive.com
(1) $160 - UC300ETH-5LPT ethernet motion controller
(2) $44 - DB25 Male Straight Connector, DIN Mount (BRKG25M-S-DIN)
# Amazon.com
(2) $8 - DB25 Female to 26 Pin Female 2.54mm Pitch IDC Ribbon Cable
(1) $7 - Siemens ECGB142 Ground Bar Kit with 14 Terminal Positions and a Ground Lug
(1) $5 - DIN Rail Slotted Aluminum RoHS 12"
(1) $20 - 2inx1inx5.6ft Open Slot Wiring Cable Raceway Duct with Cover
# cncrouterparts.com
(1) $287 - Pepperl + Fuchs Proximity Sensor Kit
- 5V/4A 12V/1A Dual Switching Power Supply
- Din Rail and Terminal Block Kit
(1) $16 - Emergency Stop
# driveswarehouse.com
(1) $338 - Hitachi 2.2 kW VFD (WJ200-022SF)
# buildyourcnc.com
(1) $339 - 2.2 kW (kilowatt) Water Cooled Spindle
(1) $29 - Water Pump - Submersible 370 Gallons (1400L) Per Hour
(1) $60 - Silicone Tubing 1/4 Inside Diameter and 3/8 Outside Diameter (40ft)
# store.sacelec.com
(1) $33 - Belden 5200FE 100ft 16/2 Shielded Stranded Cable
(1) $33 - Belden 5506FE 100ft 22/8 Stranded Shielded Cable
# Mouser.com
(1) $0.41 - Molex (39-01-2080) Mini-Fit Jr.™ Receptacle Housing, Dual Row, 8 Circuits, UL 94V-2, Natural
(10) $1.21 - Molex (39-00-0039) Mini-Fit® Female Crimp Terminal, 18-24 AWG, Bag
(7) $4.83 - Molex (44441-2002) Sabre™ Receptacle Crimp Housing, UL 94V-0, 2 Circuits
(14) $2.24 - Molex (43375-0001) Sabre™ Crimp Terminal, Female, 14-16 AWG
(4) $1.88 - Molex (39-03-9042) Mini-Fit Jr.™ Receptacle Housing, Dual Row, 4 Circuits, UL 94V-0, Black
(16) $1.90 - Molex (39-00-0078) Mini-Fit® Female Crimp Terminal, 16 AWG, Bag
(4) $2.32 - Molex (39-03-9082) Mini-Fit Jr.™ Receptacle Housing, Dual Row, 8 Circuits, UL 94V-0, Black
(32) $3.36 - Molex (39-00-0047) Mini-Fit® Female Crimp Terminal, 22-28 AWG, Bag
(1) $10 - NMB Technologies (3110SB-05W-B50-E00) 80mm fan for clearpath power supply
