Originally Posted by
1Jumper10
Quick update: Working on the Z-axis adapter plate which mounts the Z to the linear bearings on the X axis. I got some 3/4" 6061 - T5 aluminum plate off of Ebay and its enroute. I needed some different size collets for my router to hold the end mills to work on this and they are also enroute. Everything should arrive in the next couple days and before the weekend, I should have all the mechanical parts completed.
I amd going to fit this router with the standard 2.2Kw spindle. They are a good value and easy to get and mine has been working fine for a couple years now. However, I am less then impressed with the Hyuang VFD. It works OK on my current router but I know there's got to be something better available. Iv'e done a little looking around online for 220VAC VFD's and the Sunfar (KL) E500 looks better, there is a model made by LAPOND that looks OK, Hopewind looks like a good product and I thought at one time Hitachi made a decent drive but I havent found it yet. If anyone has any input on VFD's please, post it here. Thanks.
