2nd build - For a friend - Page 27
Page 27 of 27 FirstFirst ... 1724252627
Results 313 to 314 of 314
Thread: 2nd build - For a friend
  1. #313
    Mar 2014
    Default Re: 2nd build - For a friend
    Quote Originally Posted by JeremyFXDWG View Post
    I think i just figured it out. I was looking at the below diagram and could not put it together initially but Input A and B are defined by software so I would assign say direction to A and Step to B. Then it is just normal wiring like a stepper to the MB2 into the respective Step and direction terminals.
    Are you using the enable signal with the MB2?
    Attachment 362050
    Yes. The enable circuit on my friends machine runs through the E stop switch.
    Sent from my Pixel XL using Tapatalk
  2. #314
    Jan 2017
    awesome.. thank you!
    I am going to try and diagram all this out and post it up to help others too as it is a good learning process for me.
