New Machine Build Heavy steel build, ATC, R&P, Servos - Page 4
Page 4 of 4 FirstFirst 1234
Results 61 to 69 of 69
Thread: Heavy steel build, ATC, R&P, Servos
  1. #61
    Mar 2004
    UK
    Default Re: Heavy steel build, ATC, R&P, Servos
    The new gearboxes are in and they look very good.
    The pics show the 1KW motor and gearbox combo against one of the 400W servos:
    Heavy steel build, ATC, R&P, Servos-motor1-jpgHeavy steel build, ATC, R&P, Servos-motor2-jpg
  2. #62
    Mar 2004
    UK
    Well, after having been let down again by my local fabricator I've actually started on the steel work myself.
    Today I made a start on sizing all the structural steel for the sub frame. This is big stuff and very heavy: 250mmx150mm and either 8mm wall or 12mm.
    Hopefully tomorrow I will have it all cut up and then I can start on the welding.
    Heavy steel build, ATC, R&P, Servos-1-jpgHeavy steel build, ATC, R&P, Servos-2-jpgHeavy steel build, ATC, R&P, Servos-3-jpgHeavy steel build, ATC, R&P, Servos-4-jpg
  3. #63
    Mar 2004
    UK
    All the steel for the base is now cut up to size:
    Heavy steel build, ATC, R&P, Servos-2018-01-23-14-36-32-jpg
  4. #64
    Mar 2004
    UK
    Decided to finally get on with this build today.
    I started to weld one of the three leg sections together. This is a fair amount of work as the steel is very thick.
    I had to install a lifting eye on the bottom cross member just so I could flip the section over for welding.
    Heavy steel build, ATC, R&P, Servos-1-jpgHeavy steel build, ATC, R&P, Servos-2-jpgHeavy steel build, ATC, R&P, Servos-3-jpgHeavy steel build, ATC, R&P, Servos-4-jpgHeavy steel build, ATC, R&P, Servos-5-jpgHeavy steel build, ATC, R&P, Servos-6-jpgHeavy steel build, ATC, R&P, Servos-7-jpg
  5. #65
    Mar 2014
    Nice welds. But the mag drill is for feeble women folk!
  6. #66
    Mar 2004
    UK
    Quote Originally Posted by 1Jumper10 View Post
    Lol, you say that but that's 1/2" wall box section. Stuff doing that with my Dewalt XR! At least I hand tapped it.
  7. #67
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by matth View Post
    Good job Matth it sure is a heavy duty build
    Mactec54
  8. #68
    Mar 2004
    UK
    Just to let everyone know that this project is still alive.
    However a couple of weeks ago I was offered another Tekcel router that needed a bit of work at a price I couldn't refuse.
    Today was the first day running both side by side.
    When this big build is done that will be 4 routers in production:
    Heavy steel build, ATC, R&P, Servos-2018-08-29-11-56-18-jpg
  9. #69
    Nov 2017
    @Matth
    If you ever decide to get rid of the 400w servos, hit me up or post them in the classified section. I had just started looking around for servos to upgrade my machine from steppers.
    Other than that, nice looking build. Just wish I had the time and money to put into a heavy duty build like this lol.
