ok so have done a little more so far, temp setup for the z & spindle.
max down..
max up.
spindle test height.
x motor mount & bearing.
the X-leg mount & y-lead nut setup to get screw length.
glue and screw and extra ali angle bracket on y-nut mount.
temp a-fix the X-nut to the Y-rail mount and temp fix Y nut mount to X- trucks. it will be glued and a few more screws added.
as she is now .. i had some spare screw belt pulleys so using as temp screw locks for now.
until next time..
