Jason's 5x5 Router Build - Page 10
Page 10 of 10 FirstFirst ... 78910
Results 181 to 184 of 184
Thread: Jason's 5x5 Router Build
  1. #181
    Dec 2004
    Barbados
    Default Re: Jason's 5x5 Router Build
    Needed to use some cheap 60 deg bits 1/4" shaft with my hitachi router that came when we bought the 5 x 10 Maxi-Cam.
    I ordered the PreciseBits ER-20 kit for the Bosch 1617 which also fits the Hitachi 2.25 hp.
    These 1/4" (6.35 mm) collet held the shaft of the 60 deg bit which was even slightly smaller than 6 mm.
    I also bought the 1/8" collet for those tiny plastic and aluminum Amana O flute bits.
    Please note that if your router is well used that in addition to the provided instructions for cleaning the inside of the collet cone
    you should also clean the armature threads that the collet nut will screw onto. The nut would not thread all the way on until I cleaned them out with
    a utility blade. A few people have posted the reduction in runout when this kit is installed. Not pictured in the pics is the spanner that came with the kit.
    Jason
    Attached Thumbnails Attached Thumbnails Jason's 5x5 Router Build-dscn1560-jpg   Jason's 5x5 Router Build-dscn1557-jpg
  2. #182
    Dec 2004
    Barbados
    Wow have not posted in a while.
    I recently changed my BioStar motherboard to an ASRock mobo and HDD on my cnc's computer and got it back up and running without much fuss.
    Hooked the motherboard LPT1 pinouts to the cable, hooked up my hobbycnc box and off I went. Now my double Y axis and single Z axis motors
    make a bup bup bup bup sound every few rotations and they will sometimes stall under no stress.
    I believe its the new motherboard. Any thoughts??
    Jason.
  3. #183
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Check the bios for EIST (intel) or C1E (AMD) and disable it if possible.
    UCCNC 2017 Screenset
  4. #184
    Dec 2004
    Barbados
    Thanks Gerry I will try it.
