New Machine Build Steel CNC Router
Results 1 to 12 of 12
Thread: Steel CNC Router
    Oct 2012
    Default Steel CNC Router
    Hi all,
    Thought it was time to share some photos of my little project.
    Steel CNC Router-imageuploadedbytapatalk1372076262-518669-jpg
    Steel CNC Router-imageuploadedbytapatalk1372076315-334372-jpg
    Steel CNC Router-imageuploadedbytapatalk1372076349-284351-jpg
    Steel CNC Router-imageuploadedbytapatalk1372076392-634105-jpg
    Oct 2012
    The machining area will be 1400 x 2600. Servo driven on all axis. Hiwin linear bearings. Granite devices servo drives. HSD ES915 tool changer spindle. Yaskawa VFD.
    Alan.
    Oct 2012
    Some of the things that have been made on the first router.
    Steel CNC Router-imageuploadedbytapatalk1372076961-783052-jpg
    Steel CNC Router-imageuploadedbytapatalk1372076980-717313-jpg
    Steel CNC Router-imageuploadedbytapatalk1372077007-349408-jpg
    Steel CNC Router-imageuploadedbytapatalk1372077032-083905-jpg
    Steel CNC Router-imageuploadedbytapatalk1372077063-650738-jpg
    Steel CNC Router-imageuploadedbytapatalk1372077103-933359-jpg
    Oct 2012
    Very nice.
    How powerful are the servos?
    Lindsay
    Oct 2012
    Hi Lindsay,
    The z axis has a 200 watt allen Bradley.
    The y axis has a 400 watt allen Bradley thru a 10:1 bayside planetary gearbox.
    And the x has two 660 watt servos from granite devices thru 10:1 bayside planetary gearboxes.
    Alan
    Oct 2012
    Here's another sign made on my first machine.
    Steel CNC Router-imageuploadedbytapatalk1372292919-315652-jpg
  7. #7
    Apr 2007
    Nice looking chunk of wood you carved it on. What is that species called? I have some small boards of Sidney blue gum eucalyptus and curly wandoo eucalyptus from Australia.
    CarveOne
    http://www.carveonecncwoodcraft.com
  8. #8
    Oct 2012
    Hi Carve One,
    I'm not sure. I picked up a heap of wood from an old farmer in central Victoria. Australia that is.
    I'm just in idiot fitter and turner.
    It's not as nice as the boxes you have been making.
    I left it rough on the top face to give it a rustic look. It's been epoxy coated and put in a garden.
    Hopefully someone will chime in and tell us the type/species.
    Alan.
  9. #9
    Registered wayneb's Avatar
    Jul 2010
    Nice build, got some more photos.?
  10. #10
    Oct 2012
    Hi Wayneb,
    Not at the moment. I'm about 4000kms from home. The table has been final machined and I will have more photos on Monday.
    Alan
  11. #11
    Oct 2012
    Managed to get some wiring done last night. Mounted the 165 volt power supply and the wired up the magnetic contactors. Installed the rest of the granite devices cards and Bob.
    Roughly tuned the Y and Z axis also.
    But getting strange results on powering up the cabinets. The Y axis surges to the right on startup and gives a following error. The cards are VSD-XE 160 from Granite Devices. May have something to do with the hall sensing. Will investigate a bit later on.
    Steel CNC Router-imageuploadedbytapatalk1373068257-692328-jpg
    Steel CNC Router-imageuploadedbytapatalk1373068274-475451-jpg
    Steel CNC Router-imageuploadedbytapatalk1373068298-025327-jpg
    Steel CNC Router-imageuploadedbytapatalk1373068312-458355-jpg
    Steel CNC Router-imageuploadedbytapatalk1373068456-359979-jpg
    Alan
  12. #12
    Apr 2006
    na
    It's that air folded 9kw etc spindle can you give use feed back about... how well it's performed
Steel CNC Router
Steel CNC Router
