WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle - Page 136
Page 136 of 136 FirstFirst ... 3686126133134135136
Results 1,621 to 1,622 of 1622
Thread: WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle
  1. #1621
    Apr 2013
    Default Re: WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spi
    Going back to your build.
    I was looking at your wire Schematic and you have only 3 wires on the VFD to PMDX-107, is that right? Some wiring Schematic have 5 wires.
    I have the same setup as you. Also your wire diagram doesn't show the wire gauges. I was looking for the right wires to use.
  2. #1622
    Apr 2013
    WidgitMaster,
    I found your up to bate Schematic and it has the 5 wires going to the 107, sorry about that just got lucky and dug up the newest one.
    Thanks for taking the time for making the schematic, it really helps, thanks
