WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle - Page 134
Page 134 of 136 FirstFirst ... 3484124131132133134135136 LastLast
Results 1,597 to 1,608 of 1622
Thread: WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle
  1. #1597
    Gold Member
    Dec 2004
    Default Re: WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spi
    Don't forget that metal spring are rated in lbs/inch so if you have a 25lb/inch spring and stretch it 4 inches you now have 100lbs of pull!!!
    Try to find some gas springs. IIRC they have a more linear force than a steel spring.
    Mike
  2. #1598
    Gold Member widgitmaster's Avatar
    Jun 2005
    Quote Originally Posted by TOTALLYRC View Post
    Mike
    Thanks Mike!
    I did NOT know that, and it does explain a lot of the problems I'm having with springs!
    I'm going to look into the gas & pneumatic cylinders now!
    Widgit
    www.widgitmaster.com
    It's not what you take away, it's what you are left with that counts!
  3. #1599
    Gold Member
    Dec 2004
    Lightbulb Re: WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spi
    Everything you wanted to know about springs but were afraid to ask!!!!
    Extension Springs - Design Theory
    Gas spring info.
    Gas Springs Information | Engineering360
    HTH
    Mike
  4. #1600
    Jun 2005
    Gas spring info.
    HTH
    Mike
    Thanks again Mike!
    Using the Spring info, I was able to calculate the best springs for the 10" of travel for the weight of my Z-Axis assembly!
    Today I ran off a plaque to test the repeat ability & dependability of the Z-Axis! Everything is working nicely
    I made a nice plaque out of a large blanket
    Widgit
    Attached Thumbnails Attached Thumbnails WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_2141-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-sleep-veteran-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_2142-jpg
  5. #1601
    Gold Member
    Dec 2004
    WOW,
    I was actually helpful! I had better write this down. LOL
    Mike
    P.S. Nice work as always
  6. #1602
    Registered bill south's Avatar
    Apr 2005
    Widget;
    Do you have any information on using air cylinders for counter balance? I'm rebuilding an old RF45 and want to install air counter instead of shocks or springs. Any information will be appreciated.
    How is the limb coming along and did you get the new HD?
    Bill
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
  7. #1603
    Jun 2005
    Quote Originally Posted by bill south View Post
    Widget;
    Bill
    Hi Bill!
    Because the application has so many variables, you need to make a list of basic requirements!
    Such as: Max Diameter & Length of Cylinder, Stroke Length, Weight of slide mechanism, PSI available.......
    Then go to McMaster-Carr, as their product details are phenomenal, and you can find the exact cylinder to fit !
    You will also need a little push-pull regulator with gauges, so you can set the exact pressure to achieve equilibrium (enough to lift it 50% of travel), then lock the regulator!
    1/8" PVC tubing and Push-Connectors with #10-32 threads are best! Don't forget to put a muffler / filter on the exhaust port of the cylinder, this will keep debris out of the bore!
    Hope this helps !
    Widgit
  8. #1604
    Gold Member
    Apr 2009
    Quote Originally Posted by widgitmaster View Post
    Thanks again Mike!
    Widgit
    I think you got the Z sorted out... great job!
  9. #1605
    Jun 2005
    Thanks Louie!
    My friend stayed up all night painting this, and it looks awesome !
    Can't wait to see it after the Clear Coating
    Attached Thumbnails Attached Thumbnails WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-imagejpeg_0-2-jpg
    Attached Files Attached Files
    Last edited by widgitmaster; 01-10-2018 at 02:55 PM. Reason: Added Source Code file
  10. #1606
    Gold Member Bubba's Avatar
    Mar 2004
    LaGrange, GA USA
    I love it and know a Vet or two that would like one!
    Art
    Country Bubba (Older Than Dirt)
  11. #1607
    Jun 2005
    Thanks Bubba!
    I have added the source code for the plaque!
    Here's another one for the Motorheads!
    Attached Thumbnails Attached Thumbnails WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_2122-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_2137-jpg
  12. #1608
    Jun 2005
    It's amazing what a little Varnish will do!
    Attached Thumbnails Attached Thumbnails WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_2155-jpg
