New Machine Build 4'x8' RouteBot - Page 2
Page 2 of 10 FirstFirst 12345 ... LastLast
Results 21 to 40 of 181
Thread: 4'x8' RouteBot
  1. #21
    Feb 2004
    Flagstaff,AZ
    Talking
    Any progress?
  2. #22
    Dec 2012
    Default 4 x 8 CNC router design - Will it work?
    It's been a CRAZY summer and this project had to be put on hold. I now have more time and expect to start building this thing soon! I have made lots of changes. Please take a look at the latest design pictures and let me know if you see any red flags. Some of the parts in the picture below are already purchased. So I'm in deep now and there will be no turning back! I have found this project to be WAY more difficult than I thought it would be. I need all the help I can get!
    Attachment 196598
    4'x8' RouteBot-showcase_ren7_cnc-jpg
    4'x8' RouteBot-showcase_ren8_cnc-jpg
    4'x8' RouteBot-showcase_ren10_cnc-jpg
    4'x8' RouteBot-showcase_ren6_cnc-jpg
    Here are the parts I have already purchased.
    4'x8' RouteBot-imag1214-jpg
    Here is the master parts list and still growing . . .
    Rutex:
    4) R2110 - Non-polarized motherboard - 5 volts.
    1) R2010 - Servo drive for brush motors 100V/20A
    4) R2210 Single ended TTL encoder interface
    1) Chassis
    Automation Technology Inc
    3) NEMA34 850 oz/in Dual Shaft DC Servo (KL34-170-72)
    1) NEMA34 600oz/in Dual Shaft DC Servo Motor (KL34-150-90)
    3) KL-34GH101 10:1 Planetary Gearbox 4000RPM
    1) SmoothStepper USB Motion Control Board for Mach
    eBay
    Electroid NEMA 34 Power off brake
    Misumi ball screw
    Digi-Key
    4) 102-1307-ND ENCODER PROG 16RES SW TTL RADIAL
    Ugracnc.com
    7 ft) Cable Carrier 25 x 57mm
    5 ft) Cable Carrier 25 x 37mm
    Misumi
    1) GFS8-100200 100 X 200 X 1850 Extrusion
    2) HFSP5-4080 (milled) 40 X 80 X 3000 Extrusion
    1) Bulk pack T-nuts
    Automation-overstock.com
    4) Product ID: AGH15SAZ1H
    Product Name: 15mm Bearing Block, 2 Bolt Square
    2) Product ID: AGR15RxxxxH
    Product Name: AG Linear Rail, 15mm, 449mm
    4) Product ID: AGW25SAZ1H
    Product Name: 25mm Bearing Block, 2 Bolt Flange
    2) Product ID: AGR25RxxxxH
    Product Name: AG Linear Rail, 25mm, 1850mm
    4) Product ID: LGH25HAZ0H/E1
    Product Name: 25mm Bearing Block, Long Square, Self Lubed
    2) Product ID: LGR25RxxxxH
    Product Name: LG Linear Rail, 25mm, 3000mm
    More gear
    R & P gear - 20 Pitch 20 PA
    Pinion 1" Dia
    Blurry Customs
    1) Spindle (MT1073 - Y6162Y0017)
    Power S1/S6: 3Kw/3,60Kw
    Connection type: Collet ER25
    Rated voltage: 220V
    Rated speed: 18.000 rpm
    Max speed: 24.000rpm
    Rotation: Right
    1) VFD ( Delta VFD055B23A) & cable
    Misc parts
    1) Servo power supply
    Cooling fans
    Steel for table
    Aluminum for z axis, servo mounts & z axis parts
    Fuse sockets
    Limit switches
    Software
    [url]www.routebot.com[/url]
  3. #23
    Feb 2004
    Flagstaff,AZ
    I think it looks great. The overkill on the structure will allow for a higher horsepower spindle in the future if necessary. You show 1 servo drive, you need 4 I think. One thing I would do before proceeding is to source your control panels, and do a rough back panel layout. You want to make sure you don't run out of space. 10" deep should do for the VFD panel, and maybe 8" for the other. Too deep just makes it difficult to work on. They're expensive new but you can find deals on eBay if you're lucky. Looking forward to seeing your beast running!
    Kevin
  4. #24
    Dec 2012
    Kevin,
    Looks like I had 1 servo drive and 4 motherboards. That wouldn't work! Good idea on the control panels. If anyone out there has one for sale let me know. I'll start trolling eBay and see what I can find.
    Here are a couple more views:
    4'x8' RouteBot-showcase_ren4_cnc-jpg
    4'x8' RouteBot-showcase_ren9_cnc-jpg
  5. #25
    Feb 2004
    Flagstaff,AZ
    Am I the only one here with an opinion about this machine?
    Kevin
  6. #26
    I'm waiting on production of all that structural tubing, the machine is only as good as its main support structure!
    So far the concept looks solid!!
    Widgit
    www.widgitmaster.com
    It's not what you take away, it's what you are left with that counts!
  7. #27
    Dec 2012
    I'm going meet with a local machine building company next week. They may be able to supply the steel and cut all the parts. In the end I will have a table kit ready to assemble. I hope they can do it because my cutting tools are very limited.
    - Allen
    4'x8' RouteBot-cnc_frame_base_jpg1-jpg
  8. #28
    Feb 2004
    Flagstaff,AZ
    The drawing looks good Allen. Are you going to change your enclosure mounting provisions to fit standard size enclosures? I would make room for at least 16" tall, or 20" if possible. Even then you will probably need two side by side for controls. Two 16X20X8's might be okay but even that tight makes things pretty difficult. Have you considered a free-standing enclosure at least for the non-VFD controls like this one?
    Hoffman Enclosure 36"X36"X12" Nema 12 CSD363612 With Backplate Stand | eBay
    That could leave you room for future changes like larger servo drives, etc. plus isolate your electronics from vibrations. It's aslo better for cooling. Just a thought..
    Kevin
  9. #29
    Dec 2012
    I like the idea of putting most of the electrical components in a stand alone box. So I just purchased this 60" x 30" x 11" box on eBay.
    4'x8' RouteBot-capture222-jpg
    Yea . . . it needs a little paint! However, it should have plenty of room for anything I may need in the future.
    I have not met with the machine building company yet. The guy in charge was on vacation. So I hope to meet with him next week.
  10. #30
    Dec 2012
    Still waiting for more quotes on steel. In the meantime I decided to mill the riser out of MDF to verify everything is correct. The aluminum is going to be expensive and I can't afford to overlook anything. The mill cut the MDF as expected and I plan on checking the alignment with the mating parts as soon as they come in. If all looks good I'll move forward and mill the 1" thick 6061 aluminum. It's nice to see a a physical part after looking at CAD for so long!
    4'x8' RouteBot-imag1318-jpg
    4'x8' RouteBot-imag1322-jpg
  11. #31
    Dec 2012
    Just received the Misumi extrusions. They look good. I was surprised the big Y extrusion was so heavy. That thing is 72" long and weighs 82 lbs.
    4'x8' RouteBot-imag1338-jpg
    The servos and 10:1 ratio gearboxes also came in. Lots of parts and still no steel for the table. Gonna have to step up the search and get some quotes.
    4'x8' RouteBot-imag1340-jpg
  12. #32
    Apr 2007
    The 3" x 3" x 3/16" steel box tube I'm using on my own build has a listed weight of 6.87 pounds per foot of length. That would be 82.44 pounds for a 144" length. I have one extra 12' piece that I'm tempted to weigh on bathroom scales just to see if the calculated weight is close to the measured weight. I too would have expected the extrusion to not weigh that much.
    CarveOne
    http://www.carveonecncwoodcraft.com
  13. #33
    Dec 2012
    Finally got the electrical box painted!
    4'x8' RouteBot-imag1518-jpg
    Sublime green & black.
  14. #34
    Dec 2012
    Default Welding table first . . . then the CNC table!
    Steel and aluminum came in a few weeks ago. I decided to buy a little extra steel for a welding table. The CNC table will be my first ever welding project. Since I didn't have a welding table I thought it would be good practice to design and build one.
    4'x8' RouteBot-imag1434-jpg
    Lots of steel
    4'x8' RouteBot-render_weld_table2-jpg
    Inventor model
    4'x8' RouteBot-imag1442-jpg
    3' x 3' x 1/2" laser cut top and the rest of the steel ready to be welded.
    4'x8' RouteBot-imag1459-jpg
    Spot welding the 1/8" thick shelf in place.
    4'x8' RouteBot-weldtable-jpg
    Now that the welding table is done, I feel a little better about moving forward with the CNC table. It's go time!!
  15. #35
    Dec 2012
    All the steel is cut for the CNC router table. The next step is to drill the mounting holes in the 3" x 6" side beams to attach the 10' aluminum extrusions. However, I noticed quite a sag in the 3" x 6" beam sides. I knew I would need to shim the extrusions flat but this is not what I expected. Hopefully, shimming them will not be as hard as it looks.
    4'x8' RouteBot-imag1562-jpg
    4'x8' RouteBot-imag1564-jpg
  16. #36
    Apr 2007
    Aw man, you went and picked my colors and beat me to it!! I have a gallon of that bright green stuff ready to go on my new frame, maybe this weekend. Gloss black is the trim color. I'm using the Jeep Wrangler mix.
    CarveOne
  17. #37
    Dec 2012
    I'm using TCB Global's Restoration Shop Sublime Green and Jet Black. It's a 4:1 ratio acrylic urethane. I always loved the old Mopar green! The Jeep green is probably close to the same color. You'll love it!
  18. #38
    Apr 2007
    It has become a popular color. I have Stanley tape measures, Post-It notes, and see it everywhere now. Even my roadside trash bin is this kind of green and black.
    CarveOne
  19. #39
    Dec 2012
    Default Extrusion mounting holes complete
    The extrusion mounting holes are done. 3/4" socket clearance holes on one side and 3/8" holes on the other. I pre-drilled all the holes with a 1/8" bit. For the 3/4" holes I used a step drill. That was an easy way to drill the big holes in the 1/4" thick steel. 40 holes in each 3" x 6" . . . lots of drilling!
    4'x8' RouteBot-imag1713-jpg
  20. #40
    Aug 2011
    With a hand drill, no less -- that's patience.
    David Malicky
4'x8' RouteBot
4'x8' RouteBot
