Build Thread Devastator's Ongoing Solsylva Build - Page 15
Page 15 of 15 FirstFirst ... 512131415
Results 169 to 175 of 175
Thread: Devastator's Ongoing Solsylva Build
  1. #169
    Jun 2012
    Default Re: Devastator's Ongoing Solsylva Build
    Quote Originally Posted by louieatienza View Post
    With your A axis as A in Mach, or Y?
    The profile is set up for A. But I've run it in angular or distance with the same result. I think it may have something to do with the high resolution requiring so many pulses to the harmonic drive because I've also noticed that it's not just when it raises the Z, it's also when it changes direction in X after every A move. There's no ramp up to full speed, it just goes full bore.
  2. #170
    Jun 2012
    After five years using the hobbycnc ezdriver I finally switched over to the Gecko G540. Through no fault of the driver, a flake of aluminum shorted out my Z chip. So after a few hours of soldering new cable ends and configuring pin-outs I'm making parts again. I can sure tell the new driver is much stronger, those motors really get singing now. I have to make a new enclosure, right now it's just sitting loose so I can get back up and running. Nice to have the charge pump feature and of course the 4th axis so I don't have to swap cables and load a different XML every time I need to use the rotary axis.
  3. #171
    Jun 2012
    A bit of time invested in this one.
    Attached Thumbnails Attached Thumbnails Devastator's Ongoing Solsylva Build-ultimate2-jpg
  4. #172
    Mar 2003
    Can I ask how much those sell for?
    Really nice work.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  5. #173
    Jun 2012
    Quote Originally Posted by ger21 View Post
    Really nice work.
    Thanks! This one was $500. A steal at that price. Good to mach 5+.
  6. #174
    Mar 2003
    Nice.
  7. #175
    Jun 2012
    Nice.
    Thanks for the comment! Good to know that someone is still following my thread. I think I've finally found out why my Z is ignoring acceleration when I use my A axis. I believe it's my slow computer. My A axis takes so many pulses due to the high resolution that it's too fast for the lowest kernel speed. So after every A move, it tries to catch up so it skips the acceleration and tries to go full speed. How I discovered this was by accident. After I installed the G540 I decided to try a higher kernel speed. Then all the axes starting doing the same thing!
    So I think I'm going to upgrade to a computer built sometime this century, lol. But that will take some reconfiguring because my SuperPid is installed in the old computer case, so I have to build an enclosure for it.
