Build Thread Devastator's Ongoing Solsylva Build - Page 14
Page 14 of 15 FirstFirst ... 41112131415 LastLast
Results 157 to 168 of 175
Thread: Devastator's Ongoing Solsylva Build
  1. #157
    Jun 2012
    Default Re: Devastator's Ongoing Solsylva Build
    A good article in Popular Mechanics about the US Navy ramjet missile I machined the fin cans for on the Solsylva. Navy Builds Ramjet Missile with Model Rocket Engines and a Credit Card
    Attached Thumbnails Attached Thumbnails Devastator's Ongoing Solsylva Build-us-navy-fin-cans-jpg
  2. #158
    Mar 2015
    So I am at college and at my university I have unlimited free access to materials, most of which is a ton of aluminum stock and steel, as well as water jet, CNC milling machines and very large gantry. This gave me the idea that I can upgrade my machine at home for no cost other than my time, so my question is what should I upgrade on my solsylva first, mostly to minimize backlash on all axis? Or I could probabaly build a completely new machine but that would take too much of my time making the parts.
  3. #159
    Jun 2012
    Quote Originally Posted by jlowe1224 View Post
    If you have access to that, I'd say go for it. Solsylva is only for people with no money or resources, IMO.
  4. #160
    Jun 2012
    A 7075 aluminum rocket fin with bevels and polish. Finish pass was 1/8" ballnose with 5% stepover.
    Attached Thumbnails Attached Thumbnails Devastator's Ongoing Solsylva Build-fin2-jpg   Devastator's Ongoing Solsylva Build-fin1-jpg
  5. #161
    Registered Biggs427's Avatar
    Feb 2016
    That's a really nice finish!
    What's the dimension of this fin?
    Is the 7075 really harder to machine than 6061?
  6. #162
    Jun 2012
    Thank you!
    Machined area of 6" X 13". 7075 is just slightly harder than 6061, but machines cleaner because it is not as soft. I like the way it polishes too.
  7. #163
    Jun 2012
    Finished in copper anodizing. Pretty convincing.
    Attached Thumbnails Attached Thumbnails Devastator's Ongoing Solsylva Build-azinger-fin-can-crop-jpg
  8. #164
    Jun 2012
    I've got a problem that's been driving me crazy for awhile. When I use my rotary axis, Mach 3 is ignoring acceleration settings during Z retracts. Only after every "A" move. Anybody know a workaround? The only thing I can think of is to slow my Z speed way down but I'm doing engraving files so that would double my processing time. Maybe some sort of post processor that codes in the acceleration after every "A" move?
  9. #165
    Mar 2003
    Sounds like you've run into the Mach3 trajectory planner bug.
    The only real workaround might be to add a short move before the retract.
    Most people that I've seen, that run into this bug, stop using Mach3 altogether, and move on to a better control.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  10. #166
    Gold Member
    Apr 2009
    If you're just engraving, you could try making another Mach3 profile and set your rotary axis as your Y axis; use the circumference of your part to figure out steps/inch.
  11. #167
    Jun 2012
    Quote Originally Posted by louieatienza View Post
    That's what I'm doing already because I'm only using a 3 axis driver. So I unplug the Y and plug in the A, then load my mach profile.
    - - - Updated - - -
    Quote Originally Posted by ger21 View Post
    Ok, thanks. Been considering that for awhile.
  12. #168
    Gold Member
    Apr 2009
    Quote Originally Posted by Devastator View Post
    With your A axis as A in Mach, or Y?
