Ugra CNC sells two sizes of hoses. One is 3/16" ID and the other is 1/4 ID
I'm guessing the smaller size is for the 80mm spindle body and the larger size is for the 100mm spindle body.
I just plan on using a reducer for the spindle. That should be the only restricted area of the water line.
