Both the G250X and the G251X mentions it having the morphing feature. The G250X is a single drive module that you could use as the 4th axis driver. The G203V is a higher current (7 amp) version of the G250 board. The G203V has morphing even though it is not mentioned in the description. Yes, there are four G250 boards in the G540 assembly, plus a simple breakout board circuit.
See red text below:
The G250 is one of Geckodrive's newest low-price, high-quality step motor drives.The G250 is produced using brand new techniques allowing it to be sold for very low prices in volume while maintaining excellent quality. This is the drive that forms the control interface of the G540 and comes with a 2x15 2.54mm header for a connection.
- 3.5A 50VDC maximum
- Digitally filtered STEP, DIRECTION and DISABLE inputs
- 3.3V and 5V logic compatible inputs
- 300 kHz maximum Step pulse frequency
- Top settable Adjust trimpot
- Power LED indicator
- No user settable jumpers
- 20 kHz switching frequency
- Mid-band resonance compensated
- Microstep to full step morphing at higher speeds
- Small size
- Four layer PCB
- Discrete all n-channel MOSFET full bridge design
- 14A rated power MOSFETs
- 2.5mm 2x15 header in either male or female
- Recirculate mode when the motor is stopped, reducing motor heating
CarveOne
