New Machine Build MountainCrafts Router/Plasma Build Thread - Page 51
Page 51 of 66 FirstFirst ... 414849505152535461 ... LastLast
Results 601 to 612 of 791
Thread: MountainCrafts Router/Plasma Build Thread
  1. #601
    Jul 2010
    Hi Gerry, I've ripped the stuff with my table saw and edge routed the stuff to restore the radius by hand, and you're right it cuts pretty effortlessly.. So I should probably just try to figure out how fast I usually push my router by hand in such situations and go with that...
    Can you tell me a little about those eccentric work holders you made? I need to start working on a nice hold down system like that... What thickness material did you use, what did you use for the pin, and how did you mount the pin in the eccentric?
    I might even try making them out of trex.... later aluminum
    [URL="http://www.cnczone.com/forums/cnc_wood_router_project_log/124543-mountaincrafts_router_plasma_build_thread.html"][U]4' x 8' CNC Wood Router Project[/U][/URL]
    [U][URL="http://www.cnczone.com/forums/woodworking/135576-home_made_drum_sander.html"]Home Made Drum Sander Project[/URL][/U]
  2. #602
    Mar 2003
    They're just cut from 1x6 pine, with a 1/4" hole in them. I bolt then into T-nuts embedded in my table.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  3. #603
    Jul 2010
    I think I might make some from 1/8" steel, with a 1/4" round steel shaft welded to them on top, and then ground down flush... It's too late for me to install Tee nuts... In the short term, I can make a few from 1/2" MDF I guess...
    Received my 45 degree carbide tipped V Carve bit from MLCS... Received my 60 Degree V Carve Insert Bit from Tools Today today... Ordered a precision collet set today from precise bits.com (1/8", 1/4", & 1/2" collets, nut and wrench)... My S-PID shipped yesterday...
    Went into town today and ordered some hardwoods and millwork for my first paying V Carve job... Making a bunch of coasters for a non-profit to sell at fairs... Bought 16' of 8/4 Alder, 12' of 8/4 poplar, and 10' of 5/4 Sapele.. Having it resawn and planed into 5.5" wide by 3/8" thick lengths for finishing and V Carving.. Should yield about 450 coasters.. He also had some 3/8" x 3.5" poplar already milled.. I bought 6 eight foot lengths at $2.30 each of that too...
    Also picked up the hinges and draw bolt latches for the fold down wall at the load end of the table...
    Still pre-finishing 4x8 foot sheets of furniture grade plywood for a cabinet job I'm about to cut for a customer...
    I also bought a sheet of 1/2" MDF today so that I can make some of those dinosaur and animal puzzles... Gonna take a stab at that this weekend... Also need to start making some efficient hold downs for various thickness materials......
    I also have a bunch of 1.125" trex decking scraps to play with too... Been washing some of them and letting them dry...
    About to order a couple 3D models from VectorArt3D tonight or tomorrow too...
    Nice to be moving into a new phase with this table...
    Pictures/video coming soon!
  4. #604
    Mar 2003
    You're bits won't like steel ones very much.
  5. #605
    Jul 2010
    Well, my idea was that @ 1/8" thick, they should be well below the level of the material they're holding.. But maybe I should rethink all that... I'm just thinking that if I do much of the using screws into the sacrifice board routine that I have been using, it will cause little dimples to pull up all over the place.. and I'll be continually resurfacing the thing...
    Did you resurface your MDF top? If so, did you re-seal it with anything?
  6. #606
    Mar 2003
    Quote Originally Posted by Mountaincraft View Post
    I've re-surfaced it 2 or 3 times, and it's not worth sealing, as I'll just surface it off again.
  7. #607
    Jul 2010
    I think what I'll try is to pick up some 1/4" or 3/8" acrylic, and cut them from that.. then use acrylic glue to glue in some 1/4", 5/16", or 3/8" acrylic dowels (3/4" long) into them, so that the dowels are flush with the top of the cams...
    For now, I'll just cut some out of 1/2" MDF and use 1.25" long 1/4" stove bolts to pin them...
    Now if I could just resolve this issue with posting here!
  8. #608
    Jul 2010
    Gerry,
    I used your screenset to makes some cams yesterday, and to drill out a six inch grid of 1/4" holes in my sacrifice board, then take a 1 inch mortising bit and resurface over those holes (@.000 DOC), and then come back and chamfer them all with a 45 degree V carve bit...
    It makes things 'so' nice... When my Precision collets arrive, this will really get easy!
    It's also nice to have this table accurately repeating itself, so that I can trust that such operations will put the holes where they're supposed to be and that I can trust that repeat operations like the chamfering will also happen exactly where I expect it to...
  9. #609
    Mar 2003
    Cool.
    Once you use all those cool features, it's hard to imagine going back, isn't it.
  10. #610
    Jul 2010
    Yeah.. I don't want to do without these features now.. no way..
    I have a question about limit switches and your screenset and Mach 3 in general..
    What happens when the machine is running a program, gets to the M6 command, and then a limit is triggered after the machine has reached the tool change position and is waiting for the tool change?
    Would this prevent Mach 3 from turning on the spindle or doing any further motion of the system? If so, once the limit is cleared, would then pushing 'start cycle' just make everything go on as if the limit was never activated?
    The reason I'm asking, is that I'm thinking of setting up an e-stop style button on the Z carriage right above the router, that when hit, causes a relay to remove 120v power to the S-PID, and simultaneously trigger a limit condition...
    That would operate as my safety interlock during bit changing...
    Then I could pull the panic button back out, causing the relay to remove the limit condition, and also allow router power to go back to the S-PID... at this time, I'd hit "Cycle Start" and the S-PID would go and measure the tool on the fixed plate, and then go back to the workpiece, start the router, and start the cut..
    Is this reasonable? Or does a limit condition cause other problems?
  11. #611
    Mar 2003
    I'm going to guess and say "Bad Things". It'll most likely stop the macro from running. I've seen "issues" when stopping a macro from running.
    Not exactly the same, but I've hit estop during homing, and have had to reboot the PC to get Mach3 working correctly again.
    How about this option. Put a switch to kill power to the spindle. Or use the one on the router, like I do.
    Modify your M3 (Start Spindle) macro to pop up a message box reminding you to turn on the spindle. You'll have to click OK on the message box before the spindle will start. So basically, every time Mach3 tries to start the spindle, it'll give you a message to turn it on, so you won't forget.
    Another option might be to use the Tach signal from the SuperPID to check if the Spindle is spinning.
    Create an M-Code macro, and have your post place it after the M3. Wait a few seconds, and check the rpm. If it's over, say, 4,000, then proceed. You may need to add a DRO for the spindle speed, but it can be placed outside of the screen area, where you wouldn't see it.
  12. #612
    Jul 2010
    In another thread (The S-PID thread) someone mentioned that their spindle VFD sent an "up to speed" signal to mach 3 that had to be present before the thing took off...
    Are you familiar with this signal? If so, what kind of signal is it, and what is required to 'fake it'... If I could set up Mach 3 to require this signal before proceeding, and then could have my panic button allow it to get there.. this might solve my problem, no?
