Another Aussie Build - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 48 of 48
Thread: Another Aussie Build
  1. #41
    Oct 2005
    Newflavour,
    Sorry I didn't answer your question.
    I have been using Vectric products from early on and currently have Aspire.
    I can't speak highly enough about the Vectric products which are first class and easy to use.
    Mach3 runs the machine and I have invested a lot of time learning how to interface with it and make screens.
    cheers,
    Rod
    Perth, Western Australia
  2. #42
    Mar 2010
    australia
    Thanks Rod, The Vectric products do look good - I just can't justify the price tag on them right now.
  3. #43
    Apr 2007
    Think of a whole living room wall tiled with these checkered plates, with only a few randomly placed on the wall having the bubble tile.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
  4. #44
    Oct 2005
    That would be adventurous.
    cheers,
    Rod
  5. #45
    Apr 2007
    Quote Originally Posted by Rodm1954 View Post
    Yeah, now I'm wondering what the reactions would be after having a few too many Aussie Brews.
    CarveOne
    CarveOne
  6. #46
    Oct 2005
    Quote Originally Posted by CarveOne View Post
    CarveOne
    I can't print what the comments would be here. There are a few rough diamonds (pun intended) over here although attaching them to the wall might keep them out of my fridge.
    cheers,
    Rod
  7. #47
    Registered MRM RCModels's Avatar
    Jul 2007
    Rod,
    I love the build! I got some of the gravograph material and will be doing a control panel like yours. What bit/endmill do you use? Also, what depth and IPM do you use when cutting?
  8. #48
    Oct 2005
    I used a 1mm two flute cutter DOC 0.3mm and feed 1200mm/min and plunge 300mm/min. Spindle speed 24,000 rpm. I probably upped the feed rate in Mach3 to twice that feed rate as that is how I operate. It makes sure I have a conservative feed rate when I hit the reset feedrate button to 100%.
    I can remember cutting it twice to clean out the fluff from the edges.
    Hope that helps.
    cheers,
    Rod
