4-axis cutter with turntable
Results 1 to 12 of 12
Thread: 4-axis cutter with turntable
    Mar 2004
    Belgium
    Default 4-axis cutter with turntable
    Hello,
    We have built a 4-axis (stepping motor driven)Hot wire cutting
    machine. We allready have software to convert contours in NC
    code and cutting works fine.
    Now we are introducing a turntable to cut assymmetric 3D
    shapes and ruled surfaces but i'm looking for a way to extract 2D contours from a 3D model drawing file.
    By sending a new 2D contour everytime the table turns and performing a new cut. It's my final work in studying industrial engineering. does anybody have a clue?
    The attached file shows a representation of our machine
    Attached Thumbnails Attached Thumbnails 4-axis cutter with turntable-cutter-jpg
    Member HuFlungDung's Avatar
    Mar 2003
    Could you align the part axis with the turntable axis, then create a vertical cutting plane (perpendicular to the wire) to slice the model and then create profile information along the slice? Rotate the part around the part/turntable axis a bit, and the recut, etc. I don't know how you would automate this in software, but that would be the mechanical aspect to it.
    BTW, I would call your machine a 2 axis + a third axis if you add the turntable. Master and slave count as 1 axis
    Gold Member Bloy2004's Avatar
    Oct 2003
    Sturgeon Bay, WI
    Huff..
    Hmmm.. Taking bach's word, I believe that machine has independent axes at each end of the wire. This would then be the four axes. Maybe the mechanism for allowing wire to lengthen and keeping the wire taut isn't represented.
    Mar 2004
    Belgium
    Yes it is a 4 axis independant controlled machine.
    We are still working on the wire length system.
    first we used the DCAMCUT software application to cut 4-axis
    workpieces, but there seems to be something wrong with the
    postprocessing because the NC code for the U-V axis
    was wrong. So in the meantime this would be the only solution
    to go 3D .
    Unless the pro's on this site can help me out.
    thanx for the replies allthough.
    Mar 2003
    Ah, I see about the 4 axis. I was imagining a fixed length wire
    Sometimes too many degrees of freedom just creates a clutter of too many ways to do the same thing.
    Mar 2004
    I have no usefull advice, but i am very curious how you will solve your problem..
    Is the software your using custom? Control Sw?
    Thanks...
    Design & Development
    My Portfolio: www.robertguyser.com | CAD Blog I Contribute to: http://www.jeffcad.info
  7. #7
    Registered Max's Avatar
    Apr 2003
    Wow, I'm building one almost exactly like that ...
    The frame and controller are done, now working on the motor - belt drives
    I've been modeling mine after this unit
    http://www.croma-foamcutter.com/uk/F...tGDprocess.htm
    The link will give you an animated process of the machine cutting.
    I'd be interested in what software you find
    The closest I've come to is Indexer lpt as a possibilty, but until I get the machine running I won't be able to try out the software demos
    I'll try by this weekend to post some pics of what I've built.
    The two X axis (left to right) are independent and so are the two Y axis (up and down)
    I also have the turntable and a lathe table ready to be mounted ... first I need to get the basic machine moving.
    I think I've solved the hot wire tension problem by using a constant tension spring assembly pulling 6 lbs.
    Machine dimensions: X axis (left to right) 5' .. Y axis (up and down) 4' .. distance (between the two Y axis - cutting width) 2'
  8. #8
    Mar 2004
    MAX! Where are those pics?
    Curious to see what you do.
    What are you going to use it for? I want one, cuz i like the idea of making something a little less heavyduty than my planned router. it can be much cheaper and use the stuff I allready have now, like 1" aluminum square tube, and lots of NEMA23 100oz/in Steppers I jsut keep looking at an not using for anything... I wish i knew a convenient way to get some nitinol here in chicago... hate ordering stuff that costs the same as the shipping charge...
  9. #9
    Jul 2003
    "nitinol" is "muscle wire" I believe - you're looking for "nichrome" wire which is frequently sold as picture-hanging wire. Any department store will sell this, although as it's braided it might not work as well as single-stranded stuff.
    ...it does work well for pyrotechnic igniters though
  10. #10
    Mar 2004
    oh yes - good point - typo. braided nicrhome? whats it for? i need 1 thicker guage strand. I would ideally get a few guages to see what the different properties are. heres an image of my prelim design. it uses aluminum window C channel for the ways.
    Attached Thumbnails Attached Thumbnails 4-axis cutter with turntable-foam-cutter-jpg
  11. #11
    Default Re: 4-axis cutter with turntable
    Quote Originally Posted by bach View Post
    Hello,
    Hello, friend.
    You can share your DCAM cut.
  12. #12
    Nov 2011
    Mexico
    I just finished mine.
    I will add the turntable soon
    4-axis cutter with turntable-20170513_185320-jpg
