- Best Practices for cutting EPP foam
Group - I am cutting EPP foam. What are the best techniques for cutting EPP?
Some insights to the following would be helpful.
- Feed rate
- Temperature
- How to determine the right temperature
- Wire type
- Proper Wire tension
- Other variables
Thanks!
Bret C
- You may not post replies
- You may not edit your posts
Forum Rules
