Design of a new hot wire cutter
Results 1 to 2 of 2
Thread: Design of a new hot wire cutter
    Feb 2016
    United Kingdom
    Default Design of a new hot wire cutter
    Hi
    I am in the process of designing a hot wire cutter that will have to cut a 2.5 metre width and up to 7 metre long caravan from polystyrene.
    The length is no problem but the width is as it will have the shape of a crescent moon.
    What I would like to know is:- is it possible to attach a wire at right angles to the cutting wire (most likely by means of soldering it)? Has any one done this? I am thinking of having the lower cutting wire suspended in several different places along its length with wires at right-angles holding it taught, A little like the cables on a suspension bridge.
    Do you think it might work?
    thanks
    Member Reallypistauf's Avatar
    Aug 2016
    Default Re: Design of a new hot wire cutter
    Highly doubt it - post some pics or drawings of this project and perhaps I can advise
