- Help needed to go faster! :)
Hi everybody,
I'm new to this forum and I'm looking for help with my CNC machine. I have a 4.5 axis hot wire CNC machine using 12V@0.6A Unipolar Step motors direct attached to a M6 thread (pitch 1mm). The driver is custom made (full step - single phase on) and designed but the idea is simply use a TIP122 to switch phases on/off. Everything is powered by a 12V 5A power supply.
I know I cannot expect so much from this configuration, but now I'm trying to improve my machine. I can run it @ 60mm per minute (60 RPM) right now, but i'm looking for a cheap way to get more from my motors (around 240 RPM).
My doubts are:
Can I get this speed with these motors?
Can a chopper driver help me? (I have a 48v 8.3A power supply and some l297/l298 chips. I can build a bipolar chopper driver or a unipolar version using TIP122).
Is there any other alternative to get more speed?
This is my CNC (in that time it was a 4 axis only CNC machine).
Best Regards
Re: Help needed to go faster! :)
Bipolar parallel wired steppers, with modern 542 drivers.
About 1000 rpm at 48 v.
Steppers are about 40$ each, and drivers the same.
The modern drivers are silent (no hissing), dont overheat, and use soft start.
- You may not post replies
- You may not edit your posts
Forum Rules
