- Horizontal vs vertical foam cutter
Hello,
What are the advantages of horizontal-wire vs vertical-wire foam cutter? Most of the movies I've seen were with horizontal-wire machines. Is there an advantage for that or an vertical-wire is as good as a vertical wire?
Does the foam bends if it's in large size and placed horizontally (for vertical-wire cutting)?
PS. I wish to transform a CNC in a foam cutter.
Thanks and regards,
Mihai R.
- You may not post replies
- You may not edit your posts
Forum Rules
