- Newbie- DevFoamPro + Mach3
DevFoamPro + Mach3
I've recently assembled my XL RCfoamcutter and purchased DevfoamPro and Mach3 and configured it accordingly. I'm attempting to cut some simple text. My Z and Y vertical axis will move together vertically as they should. The horizontal left side A axis will move however my right side horizontal X axis does not move. (Z + A on the left, Y + X on the right). The axis are named correctly in Devfoam as far as I can tell. In Mach3 I can move all the axis manually and the home them. Any help is much appreciated! Trying to get this set up before school starts again.
thank you.
- You may not post replies
- You may not edit your posts
Forum Rules
