Where can I buy Nichrome wire from? - Page 4
Page 4 of 5 FirstFirst 12345 LastLast
Results 37 to 48 of 51
Thread: Where can I buy Nichrome wire from?
  1. #37
    Jul 2006
    Has anyone tried stainless steel leader wire? We were cutting manually just fine using .016 wire until our power supply finally went out (made the mistake of using a regular light dimmer with a step-down transformer). This brand http://www.malinco.com/fishing/hardwire.html is available in various sizes from .010 on up. http://www.malinco.com/fishing/leader_chart.html
    Best part is a package of 42 feet was 97 cents at the local Dick's Sporting Goods.
  2. #38
    Apr 2005
    I use stainless wire manually and will be on the cnc setup I have just built. Just need to do the electronics. What I use is control line wire the u control flyers use. Bought a spool years ago and still have lots. They come in different diameters and what I use is .016".
    John
  3. #39
    Jul 2006
    We got some .011 and .013 in addition to the .016, but haven't tried the others yet. At less than 3 cents per foot, why not try it? I can always use it for trip wire, eh?
  4. #40
    Registered cnccutter's Avatar
    Apr 2007
    Items for Sale
    McMASTER-CARR they have nichrome and Inconel wire(better) in all ga. (.020 831' $18.00) cheap shipping. They also have ball screws-bearings.....
    Mark
  5. #41
    Sep 2006
    Default Nickel Wire
    Nichrome wire at http://mscdirect.com all sizes and kinds and 1/3 the proce of other distributors
  6. #42
    Registered wtxrcdog's Avatar
    Dec 2004
    Hey Gil
    That power supply is the one I use. You know it works well with the inconel.
    I think I got my wire from aerowright.com
    Later Bruce
    www.wtxrcdog.com
    http://wtxrcdog.blogspot.com/
  7. #43
    Sep 2006
    You can buy Chrome Nickel fishing leader wire at Walmart. It's 69# test and 0.018 inch. It comes in a 25 foot length for less than $2. Works like a champ.
    This is the stuff at Walmart.
    http://www.thornebros.com/muskie/ter.../lc_mason.html
  8. #44
    Nov 2004
    I find several types od Nichrome wire.
    Nickel-Chrom - copper coated
    Nickel-Chrom - shining
    Ni 80 - shining
    Nickel-Chrom-Titan
    diameter
    0,2mm resistance on 1 meter 16,8
    0,3mm resistance on 1 meter 10,1
    0,35mm resistance on 1 meter 7,5
    0,4mm resistance on 1 meter 4,6
    0,5mm resistance on 1 meter 3,4
    0,6mm resistance on 1 meter 2,3
    or 0.008 0.012 0.014 0.016 0.020 0.024 inch
    My question is: wich wire to use for foam cutting and what kaind wire diameter to use. Whati is difference between this wires.
  9. #45
    Sep 2006
    I am using .018 inch, but I see a lot people using between .016 and .020 inch. I have a 115V to 25.2V, 2 Amp step down transformer. My AC voltage going into my transformer measures 124.9 and I'm seeing a little over 28 volts at my cutting wire. My power supply uses a 1 Amp fuse and so far it hasn't blown using .018 inch wire.
  10. #46
    Registered Juancar's Avatar
    Feb 2005
    Spain
    Quote Originally Posted by 43220 View Post
    My problem is wire I have on hand now breaks too frequently. Anybody recommend something that holds up well without breaking? Reason it breaks is I cut foam manually using guides the wire makes contact with and moves along during the cutting.
    Do you cut using wood templates or similate?? I used to cut wings for Rc planes using wood templates, and the wire used to break due to friction. Then I learned a simple trick: you shoul cover the edge of the template with adhesive aluminium tape, wich is used for isolating air conditing installations. Then the wire will run smoothly
    Regards from Spain
  11. #47
    Mar 2011
    China
    buy directly from Manufacturer in China, minimum order quantity is one spool.
    Here: Http://niwire.com
  12. #48
    Jun 2010
    why not just buy rene 41 wire from skyking? cost is about 60c per foot but you get a much better cut and last longer than s/s or nicrome wire.
    you can buy 50feet for $30 and its only $6 shipping to usa
    sky king rene 41 wire
