CNC Wire Foam Cutter Machines
Page 1 of 18 123411 ... LastLast
Threads 1 to 20 of 359
Forum: CNC Wire Foam Cutter Machines
Discuss DIY CNC Foam Cutting here! (R/C wing cutting etc..)
Sub-Forums Threads / Posts  Last Post
  1. Foam Cutting Software
    (4 Viewing)
    Discuss Foam cutting software here.
    Forum Actions:
    Forum Statistics:
    • Threads: 48
    01-11-2018, 11:28 AM Go to last post
  1. Mach3 and Profilli 2 Software Trubbles
    Started by bluetear‎, 10-18-2016 12:12 AM
    10-15-2017, 03:23 AM Go to last post
  2. Lightbulb Newbie- 5 axis vs 3 axis DIY for $3000? Art Student, Foam Sculpture
    Started by Books‎, 10-08-2017 10:47 PM
    $3000, axis, cnc, sculpture, unit
    10-09-2017, 06:09 PM Go to last post
  3. Unhappy Need Help!- CNC GCode not following correct path
    Started by danton721‎, 09-01-2017 05:39 PM
    09-04-2017, 12:43 AM Go to last post
  4. Build Thread- Building a new large CNC hotwire
    Started by Titan262‎, 02-18-2016 11:34 PM
    06-05-2017, 05:44 PM Go to last post
  5. 4-axis cutter with turntable
    Started by bach‎, 03-17-2004 02:13 PM
    05-15-2017, 06:50 PM Go to last post
    05-15-2017, 04:05 PM Go to last post
  6. Question Need Help!- Foam CNC mill
    Started by WilliamWorkshop‎, 05-04-2017 10:53 PM
    cnc, foam, min, needed, wire
    05-04-2017, 10:53 PM Go to last post
  7. Running a 4 axis foam cutter from arduino ?
    Started by gauravag‎, 03-02-2015 12:54 PM
    cnc, drives, mach3, software, stepper
    03-16-2017, 01:29 PM Go to last post
  8. Recycling extruded polystyrene
    Started by Making chips‎, 09-01-2007 10:47 PM
    2 Pages
    1 2
    03-03-2017, 03:37 AM Go to last post
  9. Need Help!- '4' Axis foam cutter?
    Started by Plan_B‎, 08-22-2012 04:45 PM
    02-22-2017, 03:09 PM Go to last post
    02-08-2017, 02:51 AM Go to last post
  10. Need Help!- Can anyone tell me more about this machine?
    Started by lrosenvall‎, 12-02-2016 08:06 PM
    01-19-2017, 07:05 AM Go to last post
  11. Best Practices for cutting EPP foam
    Started by BretC‎, 01-18-2017 11:06 PM
    cutting, epp, epp foam, hot wire cutter, wire
    01-18-2017, 11:06 PM Go to last post
  12. Design of a new hot wire cutter
    Started by flyerdave‎, 02-19-2016 07:53 PM
    hot, length, metre, width, wire
    10-06-2016, 10:29 AM Go to last post
  13. Problem- mach3 configuration for 4 axis foam cutter cnc
    Started by fviscusi‎, 09-19-2016 07:39 AM
    09-19-2016, 06:02 PM Go to last post
  14. Need a better wire heat source
    Started by 3Dsigns‎, 08-14-2016 11:29 PM
    2 Pages
    1 2
    axis, heat, job, told, wire
    09-18-2016, 08:21 PM Go to last post
  15. Mostly Printed CNC and cutting sheet foam
    Started by dkj4linux‎, 12-27-2015 11:32 PM
    09-17-2016, 03:13 PM Go to last post
  16. Need some mentoring (remote or local)
    Started by Reallypistauf‎, 08-14-2016 02:02 PM
    09-05-2016, 02:35 PM Go to last post
  17. Need Help!- 4 axis cnc diy hotwire cutter (raspberry pi?)
    Started by bryanlorenzo79‎, 08-27-2016 10:32 AM
    cnc, foam cutter, hotwire, raspberry, software
    08-27-2016, 11:40 AM Go to last post
Forum Information and Options
Moderators of this Forum
Users Browsing this Forum
There are currently 10 users browsing this forum. (0 members & 10 guests)
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 25 replies or 500 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
