I'm relatively new to CNC machining. I've had a manual 3 axis mill since I was 10 and used it mostly for hobby stuff.
Where is the best place to find end mills with a larger cutting diameter than shank diameter? So that I can plunge into deep holes and clear the shank. The maximum shank diameter my machine will accept is 6mm. I'm also one of those guys that likes to buy 2 cheap end mills instead of 1 expensive one...
