Shoulder Mill Help
Results 1 to 3 of 3
Thread: Shoulder Mill Help
    May 2005
    Default Shoulder Mill Help
    Hi there,
    I have a question - I'm not an experienced operator, but landed myself a Bridgeport Series 2 Interact 2 and just finished retrofitting the machine with an AJAX/Centroid Control. Now I get to learn how to use the machine. I need to mill a couple of deep aluminum pockets (3" deep) and have a Sandvik RA390 Long Shoulder Mill. The cutting diameter is the same as the shank dia, and the tool is about 8" long overall. If I run the tool down into the pocket wherein the shank is in the pocket and running along the sides - is that bad? - or should I pick up a tool where the shank has a smaller dia than the cutting dia.
    Jay
    Dec 2013
    Default Re: Shoulder Mill Help
    I have done that, but I don't like to. I have relieved the shank on the endmill, just used a bench grinder to do that. Only takes a few thousandths to have enough clearance.
    May 2005
    Thanks Jim - sounds like a plan - I'll throw it into a mill and skim off a smidgen.
    Jay
Shoulder Mill Help
Shoulder Mill Help
