I make boxes with seal I use a 1/8" bit followed by this1/8" dovetail bit from here
Single Flute Dovetail Router Bit
but this may be too small for your application.
Anybody have any luck finding a dovetail bit with a radiused top of cut so that drawers can be made on a flat table CNC router?
I have found some that will work but they are too expensive. I suppose if/when I start making money it may be worth the investment: CNC Dovetail Tooling. Looks like I will be cutting a slot in my table down through spoil board, black foam, and aluminum extrusion!
