Right, I'm not doing heavy cutting on this machine. Likely only wood, maybe some various plastics, and G10/other composite material. More than likely will never mill any kind of metal, other than *maybe* milling holes in aluminum enclosures.
I can't find the exact 220v outlet we have in the house, but it's similar to this:
Looks like it's a 3 wire, not a 4 wire, unless the middle hole is used (but all the diagrams I saw seemed to say it isn't used). Still should work for the VFD though...looks like there's no common on the 3-wire 220v outlets? I do like the idea of a dedicated supply for the machine, so I may pull a common line from another outlet. Is it OK to split a common line, so it still feeds the 120v outlet on the wall, but also feeds the 120v outlet for the machine supply as well as the 220v?
(I'd assume yes, since that's basically how all the common wires are connected in the house anyways, right?)
