nesting 8,13,16mm trespa ( solid grade laminate) router bits tip keep breakkng
Results 1 to 5 of 5
Thread: nesting 8,13,16mm trespa ( solid grade laminate) router bits tip keep breakkng
    Apr 2016
    United Kingdom
    Default nesting 8,13,16mm trespa ( solid grade laminate) router bits tip keep breakkng
    can anyone recommend a cutter we have been using pcb turbo 4flute 16mm cutter 20mm shaft diamond tips router bits, but they keep breaking off.We are running
    them at 20000rpm and 18mpm.thanks
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: nesting 8,13,16mm trespa ( solid grade laminate) router bits tip keep breakkng
    What depth of cut are you running at? Trespa is hard, and I've never cut it that fast, and not very often.
    Maybe an Onsrud 68-200 series? I have one, but have never used it.
    UCCNC 2017 Screenset
    Apr 2009
    I think the PCD as configured may shatter at high speeds... you'd have to check if your parameters put you within the recommended max SFM for the tool.
    Check out Onsrud 67-225 which is PCD with a progressive chipbreaker geometry, 3 flute.
    Apr 2016
    United Kingdom
    We have een running at 18000rpm and 13mpermin 3 passes with strict cutters now touch wood they are working will find out in coming b week 200 sheets of trespa and arpa to cut
    Apr 2015
    where you able to find a bit that lasted long and cut well for trespa?
