1.5kw spindle and er11 isn't really up to the task, adapting a big face mill to it would be dangerous, as they aren't really designed for high rpm, and your spindle won't have enough power at the lower rpm range anyways.
I would stick to 3/4 or 1" max bits, which you can find with a 1/4" shaft.
Also with a big face mill, your spindle tram has to be perfect or the surface will have big steps in it, smaller bits will leave smaller steps in the surface if your tram isn't perfect.
Sent from tapatalk
