- Need Help!- 1018 SWISS TURN INSERTS
i am trying to run some headed pins out of 1018, and chip control has thoroughly eluded me
material is 7/16 round 1018
part has a .248 shaft 1..2" long with a .190dx.200w grind relief under the head
best inserts so far have been mitsubishi sn(parallel chip breaker sharp) running 8000rpm .0008 ipr using a ccgt and coming back with a vcgt for the relief
this makes a long soft stringer that coolant washes out pretty well unless it wraps up.
trying to find a more steel friendly insert as i am only getting 200 or so pcs an edge, most steel inserts are creating an uncontrollable chip and poor finish
machine is a tsugami bo205 with hp coolant
- You may not post replies
- You may not edit your posts
Forum Rules
