- Need Help!- "PS0448 TOOL NUMBER NOT FOUND" Citizen K16
Hello All!
I am facing a problem on my citizen k16 swiss lathe and need help to rectify the problem. The problem is when I call any tool from Gang tools the machione raises an alarm which says "PS0448 TOOL NUMBER NOT FOUND". There is no explantion of the said alarm in the machine manual hence couldn't locate the cause generating alarm. However, I have found the description of alarm on other fanuc manual and which explains the alarm as illigal format at tool life data. I have checked the tool life managment pages in machine and there is no tool life count has been set, everuthing is ZERO. I have tried to set tool life but after this also the problem persists. Please suggest what can be checked or modify to come out of the problem.
Looking forward to your comments.
- You may not post replies
- You may not edit your posts
Forum Rules
