Need Help! Ideas on how to run high pressure coolant to live tooling
Results 1 to 13 of 13
Thread: Ideas on how to run high pressure coolant to live tooling
    Jan 2016
    Default Ideas on how to run high pressure coolant to live tooling
    Hello,
    I have a job we recently received. The material is brass .
    I've attached a drawing to explain. There is a .316 dia. hole in which we ream. My problem is that the only way to ream this and hold the tolerance is to get as much high pressure on the reamer as possible.
    Running this on a Citizen L20. I've also attached a pic of the live tooling holder we're using. Was wandering what others thoughts were on the best way to get high pressure on the reamer.
    Attached Thumbnails Attached Thumbnails Ideas on how to run high pressure coolant to live tooling-img_0421-jpg   Ideas on how to run high pressure coolant to live tooling-img_0436-jpg
    Jan 2013
    Default Re: Ideas on how to run high pressure coolant to live tooling
    I think the only thing you can really do is run a stailess steel hard line with is nozzle insert in it to get a good spray pattern.
    Mar 2017
    I guess you dont have coolant through the subspindle. You could drill on main and ream on sub.
    Member MCImes's Avatar
    Sep 2011
    I'm with jreynolds on this one. a loooong brake line plumbed near the tool tip is likely your best bet. I cant see many other ways to get coolant in line with the tool.
    CNC Product Manager / Training Consultant
    Jan 2013
    Does the reamer have to be live? Can it be static? If so Graf makes a nice coolant thru static holder. They are distributed by ph horn
    Mar 2017
    Quote Originally Posted by jreynolds5 View Post
    reamed hole is off-center
  7. #7
    Jan 2016
    Thanks for the suggestions. I came up with something that's working really good. The funny thing about this job is the part length and the working length of the rotary tools. I ended up having to set the length of each tool .005 off the face of the guide bushing.
    Attached Thumbnails Attached Thumbnails Ideas on how to run high pressure coolant to live tooling-img_0475-jpg   Ideas on how to run high pressure coolant to live tooling-img_0486-jpg
  8. #8
    Feb 2007
    Just a couple of things I see. If you have live tools on the sub side back working block, I would be doing that 0.316 hole on the sub. It would save time, and eliminate the problem of chips packing at the bottom of the hole. Also, from the pictures, it looks like you are using a HSS reamer. While that may work for a while, I would be using a solid carbide reamer. Costs more, for sure, but will last many times longer, especially in brass. The HSS reamer can be a big part of holding tolerance.
    Good luck!
    Mike
  9. #9
    Aug 2006
    something like this
    Last edited by hacdlux; 03-12-2017 at 08:12 PM. Reason: technological incompetence
  10. #10
    Jan 2013
    That reCool set up looks good, what is the price point on it???
  11. #11
    Mar 2017
    edp# 3720.00000 desc ER20 recool kit. My guy quoted my $615.15
  12. #12
    Mar 2008
    +1 on the Recool by Rego Fix! If they make it in the size you need...
  13. #13
    Aug 2006
    i actually have a recool in production now, we are running a 3/16 15xD drill in 316ss with a double ended live holder in our new tsugami the hardest part was figuring out the plumbing but rego was very helpfulwith that also. if you call them they will definetly help you get what you need
